B1 Buffer Preamp
Some shots of the inside -
Here is my build thread - lots of pictures and much more information;
http://www.diyaudio.com/forums/pass-labs/181552-b1-preamp-build-thread.html
I see the output RCA side grounded to the PCB but I don't see an input RCA ground reference. Did you miss something or did I?
In similar situations I generally tend to tie all the isolated back panel RCA grnds together and have one (or two if I kept them separate) ties to the PCB.
EDIT: Oh but beautiful job. Neat and well organized. Pretty chassis too!
Basically it is wired as you describe.
The grounds on the inputs are tied together, and they have their own lead to the board. The wire I used is black, and is lost in the bundle. The link has much more detail, photos and info.
Thanks for the comments!
trying to understand the PS
I've been thinking about the B1 (actually build one as well) and it's power supply.
As I see it, the concept is: take a descent DC-supply. Then follow that by a RC-filter (R1, C1, C2, C3 in the original schematic) to have a really nice supply.
Of course the PS impedance gets larger (R1 is doing that) but that is apparently not a problem because (now follows my thinking :scratch:)
1. the B1 draws only a little and fairly constant current?
2. there is enough capacity after R1 to provide the current needed (see 1.)?
If this reasoning holds, then increasing R1 gives us a lower corner frequency (less HF-noise), without penalties (the increased PS impedance is not a problem, see 1 and 2).
Please enlighten me, does this reasoning hold, or am I missing something important?
The reason I ask (of course I'd like to understand) is that if this holds, it's very easy to make a symmetrical B1 which is much more in line with the original asymetric circuit by Pass than the interesting circuits proposed by Salas (as mentioned in e.g.: http://www.diyaudio.com/forums/pass-labs/145201-building-symmetrical-psu-b1-buffer.html).
It goes like this:
Start with the (first?) symmetrical schematic by Salas http://www.diyaudio.com/forums/attachments/pass-labs/134693d1243979226-building-symmetrical-psu-b1-buffer-b1psu2xsmall.jpg. Leave out the LM317/LM337 stuff.
Take a decent symmetrical DC-supply. Follow that by an RC-filter, where the R is a preset, and feed the circuit by Salas with it. The DC-offset can then by nulled by virtue of the presets.
See pic:
Please comment on this setup. Is its smart? Is it stupid? Are regulators (LM3x7) better?
Thank you, MArco
