Audison SR1Dk output driver card, no High-side output
Can you be more specific about what you mean with 'swinging'?
Do you mean there should be a point which has optocoupler Pin5 voltage and then it jumps/swings to Pin8 voltage?
I have a pretty good digital scope, but the differential measurement calculations are not the fastest on the scope unfortunately. There is some delay
Is there an other way to check?
There are no calculations in differential mode. The scope would be used in analog mode. The scope should be able to measure anything in differential mode that it can in single channel mode.
It's difficult to measure this with the output transistors in the circuit. If I'm not mistaken, we've already confirmed that the signals were OK with the output FETs out of the circuit.
Maybe I do something wrong with digital scope with the differential measurement. Multiple forums described that differential mode with a digital scope is simply doing the math CH1 - CH2. No channel inverting and ground leads connection needed.
Do you agree with this?
There is not a specific invert button.
On the photo 1 you see the result of pressing button A1 or A2 (Ch1 and Ch2).
Pressing on that button makes it possible to change the coupling, inverting etc.
On photo 2 you see pressing the button +-
On Photo 3 you see clicking on function menu 1
On photo 4 you see clicking on function menu 2
I have not yet found the possebility to use this scope in only analog mode.
Took some time, but I found how to measure differential.
What excactly would you like me to measure?
I found out some more information. When starting up with a floating power supply on high-side HCPL3180 Pin5 and Pin8 it works perfectly, also after disconnecting the floating power supply while operating it works perfectly.
It seems like it only has problems when starting up without a floating 15v supply.
Ok so, without supply and with output fets installed.
Photo 1 is HCPL3180 pin 6 referenced to secondary GND
Photo 2 is HCPL3180 differential between Pin5 and Pin6
Photo 1 Q24 base
Photo 2 Q24 emitter
Photo 3 Q25 base
Photo 4 Q25 emitter
