New Phono Parts list
Peter-
Re: your new phono circuit - any chance you could post the parts list (and/or schematic) so we can start sourcing parts for this unit while the PCB is underway?
Best regards,
Mike
Peter-
Best regards,
Mike
Drop me an e-mail and I will get you the schematic, I'm reluctant to post it here.
Didn't even see that one.
EUVL said:Did you try the LC Audio circuit ?
Why I asked ?
See how they use the AD844 in open loop.
AD844 in open loop is supposed to be one of the opamp secrets.
Patrick
Patrick
Hi Peter
I've quickly searched to see if you are still offering your NOS DAC PCB's without luck. At the time I built one of your amps a couple of years ago you were offering a 'Blue' (?) and a 'Green' gold plated board. Are either of these still available.
Apologies if i've missed an obvious post/ link.
Peter, that is an impossibly small heatsink you are using!!
I would like to try a very similar thing. I have many questions about it... What CPU voltage, FSB and multiplier settings are you using? Do you know the power dissipated by the CPU and the performance of the heatsink in deg C per watt? What kind of CPU temperatures do you get under load? Are you under volting and under clocking the CPU? What are the dimensions of the heatsink?
I have an Athlon X2 that I am running at 0.88v and 1GHz. My best estimate at power output is 15W max. Do you think that compares well to your setup?
Peter,
Any update on the phono kit, very interested, assuming you will be offering a premium version as always?
I've already built first prototype, using those boards, and it came out really nice. I'm still experimenting with fine trimming of PS and smaller heatsinks, but other than that, the circuit is complete. You may notice that it's quite similar in a form to the DACs 😉
If interested, contact me about the boards.
Hi Peter
Yes, those are available, please contact me through email.
Check out the discussion starting with post #2374: http://www.diyaudio.com/forums/showthread.php?t=51381&page=119
I'm presently using Gigabyte mobo and E7200 CPU. It runs really cool and fan was not needed; IIRC the temp was below 50 deg. Recently I added small fun just to be safe and sometimes, for critical listening, I simply take it off.
A phono stage circuit will be available soon. I've been experimenting with it since last winter and finally came out with a version that practically competes with anything out there. A first prptotype have been already presented here: http://www.diyaudio.com/forums/showthread.php?s=&threadid=145383 however the board pictured below is much more practical and convenient. The phonostage circuit is coupled with a shunt reglator (which is double the size the phonostage itself) in a package similar to previously offered NOS DAC design. Both sections can be separated and used on its own.
The boards go into production next week and should be available in 3 weeks or so, after I'm back from my European vacation 😉
Man, Peter, I can't wait! Seems like it has been longer than a year... 😛 But I'm glad the wait is over.
Usb dac
Finished assemble the USB DAC yesterday. I would like to know is there any check or test point I can measure to make sure the DAC is in good working condition as the DAC can not be detected by all 3 of my computers, one Mac and 2 PC.
Check all 4 voltages after regulators: it should be 3 x 3V and 1 x 8V
Also, power on DAC first, after that computer.
Hi Peter
The problem is just fixed. There was one cold soldering point at one of the leads of the crystal. Sorry for confusing.
Peter,
Sorry, I can't trawl through the whole thread.
What is your recommended cap to go with the premium 3875 kit? Did it end up as the BG N 100u?
And could you supply me with a premium kit including the recommended caps, but not including pcbs or PS parts? I intend to wire it point to point.
thanks.
thanks.
The recommended cap is the one supplied with a kit: Panasonic FC 1500/50. Some people prefer it over BGs.
The Black Gates sounded better to some other people, but presently are not available any longer.
Additional info on caps can be found here:
http://www.diyaudio.com/forums/showthread.php?postid=574431#post574431
http://www.diyaudio.com/forums/showthread.php?postid=581230#post581230
I can supply partial kit, please email me.
Peter-
Got my LM4780 kits in the mail and am now working on them (quick shipping !)
The skematic calls for 2.7R resistors...im assuming the 1.5R that came with the kit are the replacement? Also, the skematic also calls for .1uF caps in the Cz location on the board. The closest that came with the kit are 10uF electrolytics. If these are to be used, are they to be positioned short rail to the ground side? (I have some 0.1uF poly Film 63v caps available to be used as well...would they be better suited?)
The 2.7R and 0.1uF are optional Zobel components and I do not recommend using them, that's why they were not included.
There shouldn't be any 1.5R resistors there, the 3W 0.1Rs are used for parallel configuration only.
You will find more info here: http://www.diyaudio.com/forums/audio-sector/155635-kit-arrived.html
- More Vendors...
- Audio Sector
- AudioSector-chip amp kits, dacs, chassis
