cyxg said:
i also got USBDAC from you. it's very good sound and convenient to play WAV or APE by Foobar2000.
cyxg
Give the DAC a good 100 hours to fully open up. The blackgates continue to get better over 300 hrs. I leave mine on all the time and it is excellent.
Then drop Foobar and pair CPLAY & CMP to this DAC and you will be blown away. Very short USB also good.
http://www.audioasylum.com/forums/pcaudio/messages/3/31286.html
walter
wlowes said:
cyxg
walter
thank you walter.
i will try.
Peter, it has been a couple of months and was wondering if you have anything to report on the "more serious project"
'All in all, I'm very content with that unit and I use it in my workshop for music, internet and video. I have another, more serious project coming up soon.'
Peter
would you give your recommends for a BG (N and STD) substitutions
are nichicons (too many types) good, rubycons or pana FM/FC
Hi Samoloko,
I've never heard of real substitutes for Black Gates when it comes to electrolytic caps in coupling / decoupling applications. Further more, sound of caps really is a matter of personal taste. I would go for some nice film caps, MKP's or KP's.
If size matters, I would recommend to outsource the caps from the pcb completely. Then you have the possibility to try every cap you want.
I did the same in a recent project when I decided to use some russian military pio's, bypassed with a small film cap of same value. Very nice result, and much better than some ordinary electrolytics...
Regards - martin
Regards - martin
samoloko said:Peter
If not BGs then Panasonic FC; some people also like BC Components caps, but I never tried them.
thx for very kind reply Martin
It has to be a electrolitic cap which has closer to BG N sound
I don't have much practice thats why I ask
Ok, then perhaps this test might show you some alternatives:
http://www.ecp.cc/cap-notes.html
There is also something said about some Panasonics and Nichicons.
Happy reading ;-)
Regards - martin
Happy reading ;-)
Regards - martin
Peter
have you think what you would use for a replacement of BGs
after all they are not In production
why do you like pana FC more than FM
also what you think about nichicon and rubycon for couple / decouple
I expressed my views on capacitors here: http://www.diyaudio.com/forums/showthread.php?postid=574431#post574431
http://www.diyaudio.com/forums/showthread.php?postid=581230#post581230
I've been using Panasonic FC for many years and don't plan replacing them with anything else. BGs were fine, but only for limited production of certain amp models. I still keep substantial stock of Black Gates for future needs (to be used in actual products only and not sold for parts).
And why would I like FM if FC work fine for me? 😉
The only other caps I would be interested to try out are already mentioned BC Components (used originally in Gaincard)
Hi Peter,
following the building of my amp based on your LM3875 kit I am thinking of connecting remotely my Mac to the amp building your NOS dac. Is it posible and how to connect the dac to an Apple Airport Express WI-Fi?
I read that Airport Express has a 3.5mm jack digital out (S/PDIF).
Renato
Renato
Sorry I get confused. Somewhere else I read that Airport Express has a toslink digital output not S/PSDIF. But the question is always the same: is it possible to connect it to the DAC?
Renato
Renato
Hi Renato,
This should work:
http://www.twistedpearaudio.com/digital/torx.aspx
Good luck, I had a Monica dac and never could get it to work with toslink for my airport express. My future plans are to go directly from the mac to a usb dac.
This should work:
Hi,,
thank you for the answers. There is also the possibility suggested in post #2629, that is more or less to build a diy airport express box connected via usb to the dac.
I think it is some more effort and expensive than airport, but with increased flexibility.
I got the job for next September
Renato
Renato
OT info on trafo
HI peter you have same good experience with hammond 229 series in your dac ,I want upgrade the toroid on phono and driver psu , the 24VA and 48A have 15% regulation , as I need 50ma and 100ma you can estimate the Vout and the coils is matched ?
thanks for your time
emanuele
emanuele
A phono stage circuit will be available soon. I've been experimenting with it since last winter and finally came out with a version that practically competes with anything out there. A first prptotype have been already presented here: http://www.diyaudio.com/forums/showthread.php?s=&threadid=145383 however the board pictured below is much more practical and convenient. The phonostage circuit is coupled with a shunt reglator (which is double the size the phonostage itself) in a package similar to previously offered NOS DAC design. Both sections can be separated and used on its own.
The boards go into production next week and should be available in 3 weeks or so, after I'm back from my European vacation 😉
- More Vendors...
- Audio Sector
- AudioSector-chip amp kits, dacs, chassis
