Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
When I had on 3.3V connected there was life on the Receiver Pi DDC and the ES9038Q2M Dual Mono II DAC only. 5V was available and on from the PurePi II. The FiFoPi Q7 was totally dead, no lights, nothing from the Monitor Pi Pro at all. I read the manual over a few times and kept stopping at the part where it said Q7 requires both 3.3 and 5V, Q7II is 3.3V only. Then after reading that 5V is transferred from the PuerPi II through the RPi GPIO pins I realized that the ReceiverPi DDC makes no connection at that level I realized that connecting 5V from the terminals on the PurePi II to the FifoPiQ7 was the only way to get it 5V. I re-read everything again, searched on here and came across a post where it said both voltages were required.
I took a small leap of faith and connected it and viola!
I get what you're saying and at first I felt the same way but I started probing with a meter and realized the 5V was needed but not connected
Hi @sbelyo
I have reviewed the documentation to ensure nothing has been overlooked. Here are my observations for you to verify:
• In your stack, have you connected a GPIO connector received with DDC between Pure Pi II and DDC?
J6: Optional 5V Ultracapacitor Output
• J6 serves as an optional backup output and is internally connected to the same 5V output as J4. It can be used if required by the application.
• However, if GPIO power flow is established via the GPIO connector, J6 becomes unnecessary.
• Based on your setup—where Q7 functionality was achieved only after connecting J6 to the Q7 5V pin—it seems you may not have used a GPIO connector between Pure Pi II and DDC. Please correct me if I am wrong here.
Why Avoid J6 Connection?
• J2 is the only pure, fuse-protected output available. J6, on the other hand, is an ultracapacitor-based output, which is not pure.
• It is preferable to route power through J2 + GPIO, as this should work best for your stack.
Troubleshooting
• Important before making any steps or even making GPIO contacts. : Remove the J6 5V Pure Pi II connection to Q7 5V. Also remove Batteries from Pure Pi II
• Make sure GPIO connector is properly connected between Pure Pi II - DDC. Then from J2 3.3V of Pure Pi II make connections to both Q7 3.3V and DAC J1 which is AVCC.
Power ON the Stack with all remaining connections set. batteries also reconnect but no J6 connection please.
Should be all good by now.
• If your stack still fails to turn on or shuts down within 1-2 seconds of powering up, consider replacing the official RPi power adapter you are using. Try using a different 5V ≤ 3A adapter, such as a mobile charger or an iPad 5V 2.4A adapter, which tends to work well.
This must bring the stack Live utilizing full capability of Pure Pi II's ultimate Pure Power. All the Best!!!
So...I switched over to the OPA861 I/V board this weekend from the Transformer I/V. I now have an upper level distortion that was not there before. It is subtle, but I mean that's kind of the point, get rid of subtle distortion. The only thing I can think of is a bad connection some where, but since the only thing I changed was the I/V board, I don't know how that would change.
So my setup consists of, a Station Pi SMT, RPi5, Receiver Pi DDCII, Q7 II, Dual Mono DAC, Monitor pro. I am wondering if my PSU is the problem too. I was able to get a 3.3 UCPure to power the Q7, when I first started I picked up the and I got a UCPi to power the 5V section, now I'm wondering if that's the weak link, although, the OPA has it's own PSU so I don't know whyt that would do it. Also, I am powering the OPA with two UCPur MKIII with a medical grade transformer that Gabby recommended.
https://www.digikey.com/en/products/detail/triad-magnetics/VPM24-2080/5721751
i have a FiFo Q7 (the older version), which has been working fine until recently. During the last few days I have noticed that my Ian Canada streamer cannot exceed 44.1kHz (according to the Monitor Pi Pro), although I am feeding it with HiRes streaming content (98kHz). I am using LMS 9.03 (Lyrion) and Squeezelite.
Any clues? Thanks in advance.
After some more testing and taking some things apart I think I just happened to pick some really bad recordings after I installed the OPA. In the process I fixed something completely by accident and then screwed something else up. When I installed the Receiver DDC, I had some pretty bad delay between the picture and sound. Some how I resolved that, every thing was playing fine, and I went to turn every thing off, changed my mind to check something else, turned it back on, all the LED's light up, the Q7 locks on, but now I get NO SOUND...ARRGGG! Nothing. The LED's are all lit up, when i hit play the Q7 locks, and it locks when playing from a thumb drive DSD files, Tidal from Volumio, and my OPPO from the receiver DDC, which was working perfect a few minutes ago, now nothing.
It's almost like the DAC is screwed up, which I don't know how it's possible, I literally did nothing but cycle power!!!
Issue solved with the help of Antonello. I had to delete and reinstall Squeezelite.
Issue solved
I wish I could say the same. I have no sound now. Tried re-install of Volumio and no luck. I'm not even sure what to try next. I've been racking my brain trying to figure it out. All the LED's light up, except the DAC "lock" LED. It's really strange because all three power LED's are lit up, and when I press play on Volumio, the "lock" LED on the Q7 lights up too, and the I2S LED on the back of the Q7. Same thing when I play DSD files. Everything lights up like it's playing but I have no output, and yes I checked the Monitior pro hardware volume control. It's weird...and it sucks and its frustrating...
have you tried going back to the Transformer I/V. maybe it's a broken OPA.
Reactions: Clausen
Yeah, I tried that last night.
Is the monitor pro on the right input
This is part of why it doesn't make sense, when I switch the DDC on the Monitor Pro between inputs, the "lock" LED cuts on for the OPPO input, and when I switch back to RPi, and when I press play the LED's turns on and then off when I stop it from playing but no sound. It was playing when I cycled power and did NOT start playing again when I powered it back on. I did have the Monitor Pro turn the volume thing down one time, not sure why, but all I had to do was turn the knob and the volume came back up. I'm still wondering if there was a power surge or something that fried the DAC. D2 and D3 do not come on.
