Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
I do not have Q3, so a bit expensive to test if it works in my setup. The FifoPiQ2 is working perfectly with two Crystek XOs, but when replacing these with the SinePi and one or two external Andrea clocks (45/49 MHz) the SinePi relay keeps switching between the two clocks no matter what the FifoPi input sample rate is. The clock outputs seems fine. Of course it is also possible that the SinePi is malfunctioning.
Hello,
I just ordered the adapter and some new cables in Canada hoping this will solve the problem.
The cables i used were the ones recommended by Andrea .
I read that sometimes these u.fl connections can be problematic so using the ones Ian is using should be safer.
Greetings,Eduard
Reactions: SimonJ
