Peter Daniel said:I don't know if it's F1, but it's Grado with a green dot.😉
Newer than an F1 then, F1 has F1 right on the front.
dave
Re: More Pioneer
Stock, it doesn't sound very good. Suitably damped to reduce resosnance in the arm/casework with feet removed, it easily beats the Linn and others. I bought mine for less than $150.
-----------------------------------------Peter Daniel said:And that's PL-L1000 linear tracikng turntable.😉
Re: Re: More Pioneer
Really? What you do for feet and how about more info on damping, I didn't know that unit could beat Linn. I bought mine for $200.
Re: Re: Re: More Pioneer
Start with damping chasis. But the key area is the guide rail and carriage for the arm. I used sorbothane grommets and bitumen strips. The whole thing probably needs a clean up. Use spikes in place of the feet, and reinforce the support area. Unit must be levelled precisely and mounted on wall support. The player works very well with a Dynavector XX1L.
---------------------------------------------------------------Peter Daniel said:
If this thing after the mods will beat my Maple Noll air bearing turntable I can honestly say it was one useful thread.😉
Thanks fmak.
Thanks fmak.
Freebies.
I got given a pair of Canton GLH-100 loudspeakers today.
An hour later I had the bunky dome mid driver fixed and they work a treat.
Heavy cabinet, diecast 12", doped dome mid and doped dome tweeter and pretty extensive XO.
I cranked them for an hour or so on my repair bench amp and they are quite decent.
Yippee, new reference monitors. 🙂
Eric.
Eric.
Joined 2002
All Show, No Go
Ther were some classic looking bits of gear of that period.
I've repaired a CA-3000.
The listening test was only long enough to confirm correct operation of all thos knobs before my ears hurt.
Eric.
Eric.
All Show, No Go
And this is what it's all about. Just looks and nothing more.😉 I don't even try to listen to those pieces. But I've always entertained the idea of building something really high end in one of those boxes. If only I had enough time.😉
Lotsa Show, this one doesn't go at all...
I'm guessing this is a euro model -- when i worked hifi the NA model was silver and called the SX-1280. Should have a nice power-supply in it.
dave
dave
I'm currently using these in my system. AR SP4 Pre-Amp (Video and tuner) from the 80's and a Heathkit AD 1702 electronic xover (Sub-Bass) from the mid-70's. I used to love playing with the Heathkit stuff. I still use the Heathkit Audio Generator and FET VOM (Analog to 100kHz). In the 60's, we had two stores in our area (Detroit).
Rodd Yamas***a
Rodd Yamas***a
Re: All Show, No Go
This is a generalisation. There are some good sounding stuff. The Leak valve tuner and the Marantz tuner are excellent. Also some Japanese high end ones like the Pioneer CX, CZ and HZ amplicaation components.
----------------------------------------------------Peter Daniel said:And this is what it's all about. Just looks and nothing more.😉 I don't even try to listen to those pieces. But I've always entertained the idea of building something really high end in one of those boxes. If only I had enough time.😉
Re: Re: All Show, No Go
I agree.🙂
I agree.🙂
Genuine US Audio Gear
Rodd, those look distinctly non Japanese - no Matsu****a at your place ?. 😉
Eric.
Eric.
This is true. You find some of the good stuff, under the least expected labels -- Hitachi, Toshiba for instance made some sleeper product.
dave
fmak said:This is a generalisation.
dave
Peter,
What, do you run the Toronto Royal Audio Museum?
Eric,
I would want anyone to think I've been swayed by my ancestory.😀 (that smiley thing looks like a caricature of a Oriental person)
I do have the "Jap-Crap" in my system, an it can be characturized as "old".
Here's my Nak' BX300 and Technics SL1700. The Nak' is for when I'm lazy, but I can do some real listening with the 1700 (with a Grado).
Rodd Yamas***a
Eric,
Rodd Yamas***a
- Anybody into older, classic looking gear?
