Another quasi-complementary design
Very low voltage ,donatel. If you could post high resolution
pictures of your board.
Many burnt mosfet's I've read about lately, wish I had them all.
Also , I do the Idle bias right at the emitter resistor (R29/30-.22 ohm) = 22mv for 100ma / 11mv for 50ma
bad Hf performance/burnt OP stages sounds like severe
oscillations.🙄
oscillations.🙄
Thanks for the answer, therefore do you believe that the motive for my breakups is due to the fact that my tension is too much low? Are R29 and R30 already from 0,22 ohms, only that have not understood still the setup of this amplifier, if I set to 0,3 or to 0,4 voltses??? I think that the greatest error is this...
Hi Ravslanka,
I've examined the voltages you have posted and they are close to what they should be but not quite, so you could have a genuine fault. Using DC rails of 43 volts means you must change R7 otherwise T2 will not work. Change this to 18k before you continue and check if this fixes your problem.
Now lets have a look at the circuit in this order.
The constant current source in the first stage sets a voltage across R4 and across R9 of about 3 volts. This voltage appears on the bases of T6 and T8. If you allow for the b-e junction of these transistors you must have about 2.4 volts between the emitters of T6 and T8 and the positive rail on R15 / D5 etc. Allowing for voltage drops across R18/R16 VR2 and R15 you should have about 1.5 volts across the c-e of T5.
But you do not have this so pull out T5 and check it. If it tests ok make sure that it is connected correctly. Then check T4 and D5.
Now back to the first stage. If you do not have about 3 volts across R4 and across R5 check that the constant current source is working. The easiest way to check this is to measure the voltage across R7 (now 18k). The differential here should be about 32 volts.
Lets make the above checks first and let me know how you get on.
Note, when setting the bias for the out put stage do it very slowly. Allow the amp to warm up with the bias set to half what it should be and watch it closely as it rises slowly to a much higher value. Gradually back it off if you need to and set it finally after 15 minutes or so.
Cheers
Q
Cheers
Q
quasi said:
Hi Ravslanka,
Cheers
Q
Cheers
Q
hi quasi
thanks for your reply
here are my measurements
with biasing off 0.60 volts for 2 pair mosfets and 42.3 volts dc rail and 10 ohm resistors in both rail
across r4=2.83 volts
r9=2.66 volts
the same voltages on bases of t6 and t8
from positive rail to emimiter of t8 its 1.94 volts and for t6 its 2.04
from positive rail to base of t8 its 2.80 volts and for t6 its 2.64 volts
across c-e of t5 its 1.30 volts
voltage across r7 its 32.5 volts
so i think constant current source is working
voltage across
r17=3.5 volts
r19=3.4 volts
voltage on positive fet with one meter lead connected to ground
g=3.5 volts
d=41.6volts
0.083mv
and negative fet
g=-39 volts
d=0.056mv
s=-41.3 volts
for t8
e=40.3 volts
c=3.5 volts
b=39.6 volts
t6
e=40.3
c= -1.1 volts
b=39.5 volts
t7
e= -1 volt
c= -39 volts
b=0.10 mv
t5
c=40.8 volts
b=41.7
e=42.3
t4
cb=42 volt
e=40.9 volts
t3
c=39.4 volts
b= -0.076mv
e= -575mv
t2
c= -33.2 volts
b= -41 volts
e= -41.6
giving clear buzz when connected to a speaker
not tested with one fuse and one 10 ohm resistor yet
so quasi is it working ok is it ready to play yet
quasi said:
Hi Ravslanka,
Cheers
Q
Cheers
Q
hi quasi
r9=2.66 volts
voltage across
r17=3.5 volts
r19=3.4 volts
g=3.5 volts
d=41.6volts
0.083mv
and negative fet
g=-39 volts
d=0.056mv
s=-41.3 volts
for t8
e=40.3 volts
c=3.5 volts
b=39.6 volts
t6
e=40.3
c= -1.1 volts
b=39.5 volts
t7
e= -1 volt
c= -39 volts
b=0.10 mv
t5
c=40.8 volts
b=41.7
e=42.3
t4
cb=42 volt
e=40.9 volts
t3
c=39.4 volts
b= -0.076mv
e= -575mv
t2
c= -33.2 volts
b= -41 volts
e= -41.6
please do comment soon
thanks in advance
ravs
Re: Go for it
quasi said:
Hi Ravslanka
Things seem ok so go ahead and replace the fuse and connect your speaker.
Enjoy, but remember you are only running 2 pair of FETs. If you increase the rails then you will need more FETs.
Cheers
Q
thanks quasi
after warm up time of about 20 minutes with fuse and resistor
biasing of 0.60 volt and dc offset of 0.3mv.after that i replaced them with fuse everything is fine.i connect the speaker feeding the amp with computer output the sound is not clean it is breaking.
the i switched it with bigger supply with same biasing and dc offet
and dc rails of 76-0-76 and aux 86 volts with two pairs only for testing purpose .fuses in both rails rhe situation is the same. broken sound. what iam doing wrong.
voltage across
r4=3.24 volts
r9=3 v0lts
r7(27k)=53.3 volts
r19=3.32 volts
r17=3.61 volts
voltage across c-e of t5 1.48 volts
r16,r18=0.22 volts
please do reply soon
regards
ravs
ravs.
All those voltage are normal.
Looks to me like your power amplifier works just great.
Question1:
What is voltage across R32 and R33 (0R33)?
Is alright if is 0.010 Volt - 0.020 Volt (30-60 mA in each MOS)
Question2:
You have one CD-player?
With some volume control.
Maybe this can give better sound.
If maybe your PC output is not perfect good for Power Amp input.
lineup said:
ravs.
Question1:
Question2:
hi lineup
i have checked it already with a cd player and a pre amp from (esp)
i think only one side mosfets are working
voltage across
r32=31.4 mv
r33=0 volts
quasi said:
Yup, that sounds like a problem to me.
Check to see that you the FET gates are actually connected to the gate drive resistor. Do you have access to a CRO? This will let you look at the audio signal at the various stages of the circuit.
Anyway you will need to check the output FETs for both a short cct and open cct condition.
Good to hear Nmos200 working.
Cheers
Q
hi quasi
as you said i removed my fets and checked them they were were all ok. but i replaced them with new one .only one pair. the problem still remains.then i increased the biasing current to 1.20 volt the sound is clear now.with rails of 43 volts no auxilary.the amp is running for an hour with only one pair.the driver heat sink is cool main heatsink is a bit warm.is it ok to allow this much current to fets.iam planning to further increase the current to 1.30 volts.after that i will put all fets back to the board.suggest the voltage should go te resistor for 3 and 6 pair versions.
thanks in advance
ravs
