I can not believe that the tracking compensation makes enough difference to the reproduction to overcome the mechanical losses
It's a pity that tonearms are so infrequently measured, and so little standardisation of measurement for them.
It prevents us getting at least a partial answer to these claims or doubts.
we have an interesting tonearm here that pivots in all directions. Check it out!
Wow. Kind of steampunk in a way, Victorian 19c engineering at its most florid. What would be the effective mass? All those single point bearings, all adjustable. My Dad used to call the Vincent motorcycle "a collection of solutions in search of a problem". Thanks for that, directdriver. I love this thread; I am beginning to suspect that the arm that exhibits completely perfect tracking geometry is one that just doesn't work as an arm. Like a stopped clock shows the right time twice a day only.
Cheers Steve
It looks like that over-engineered Japan arm addresses another problem: change in VTA on warped records, together with tangency. That problem is real, and solution is interesting. At least someone tried to do something about it. I'm not talking here about turntable flattening ring etc. I've tried something alike myself, just not satisfied with results. Solves one problem for the cost of creating other ones...
Hi all.
I've been posting in several related threads but not here before.
Unfortunately just keeping the cartridge level will have very little effect in reducing VTA error. The angle through which the arm rotates on its vertical pivot is relatively small. The vast majority of VTA error is due to the angle of the surface of the record, for the surface to go up and down the surface must tilt. Whilst researching for my arm build I measured the actual warps of a random selection of my collection. Very time consuming but it gave great data. The effective length of an arm would have to be only about 30mm before pivot VTA error was as significant as the surface angle VTA error. A vastly simpler solution to VTA error is a good reflex clamp. Some problems are better dealt with at the deck and not the arm.
Niffy
I love that quote. Some might call it reinventing the wheel. Your dad is wise.
You at least understand the entertainment value of this thread! 🙂
steampunk
More pictures of the multi-pivot tonearm, in disassembled mode.
According to Google Translate, the text says the arm squeaks(!) so the maker has to pad it with some cotton! Hilarious!
We might laugh all we want but I bet the maker was having a fun time building this!
One is not enough, you gotta make two!
John Cage would approve of this tonearm. 😀
I also like the really out there LPs that are displayed with this arm. Extreme music demands extreme solutions!
Cheers Steve
Cheers Steve
Easy does it
Today I saw the Thales Easy tonearm in person at an audio show and it's really delicate and beautiful. It was a silent display so I couldn't hear it. I did see it pivoting and it's extremely low friction and smooth. Too bad I didn't take a picture. It only confirms to me that this is how I wish the Simplicity should be made using the tetragon geometry. Too bad the Easy has to resort to the Burne-Jones type geometry. The guiding rod does not have to deal with vertical movement at all, only affects horizontal plane. Clever. Here's an hi-rez graphic image for today. If I can take a close up picture tomorrow, I will post it here.
Thales Simplicity
The close up view of the dual wand design and its headshell bearings exposed.
Thales Easy
Not the best resolution picture but you can a idea of its construction. Counterweight is not shown. This is so much more elegant than the other Thales arms that I wish they can make the Simplicity this way using the "tetragon" geometry.
Put a realistic knuckle on that thumb and we might be able to make a pivoting headshell out of it. 😉
The adjusting screw on the headshell bearing tells me that play/friction is absolutely crucial, and probably perfection hard to achieve on the Easy arm. Bit Garrard Zero 100-ish, but probably better made.
Cheers Steve
Cheers Steve
I agree. I think the RS Labs style headshells try to achieve equal mass around the pivot but adding a "counterweight" at the opposite side of the cartridge mount. I think that helps to lessen the bearing friction. Of course at the same time it increases the overall mass at the headshell.
RS Labs type of headshell...It looks like nobody understands how it really works, including it"s designer. Why headshell pivot point is on the same axe with diamond tip (and not with the cantilever pivot point)? OK, lets assume it still is able to decouple horizontal part of vibrations, so what about the vertical part of them? What good it may do to the stereo sound, recorded 45degrees by 45 degrees, where half of each channel signal comes from vertical modulations?
Actually, listening test will answer if that design works. One part with recommended setup, another- with rigidly fixed pivot point. May be I'll try to do it and share results here.
I would love to hear a description of what the RS-1 is trying to do, in English that I can understand. Reading the manual only confuses me.
Also, is it a good idea, or not?
- Analogue Source
- Angling for 90° - tangential pivot tonearms
