Amp Camp Pre+Headphone Amp - ACP+
Not sure if I am looking at it correctly, but the Vf and Ic value seems off from the datasheet on digikey. See picture. Not sure what else to do now. The Korg Nutube B1 I recently built was much simpler and straightforward.
you can use those testers to check functionality and pinout, not to compare electrical values with given ones in datasheet
can you check voltages at important points in circuit?
drain of Q5 (ref to gnd)
voltage across any source resistor of output mosfets
voltage across R4 (ref to gnd)
voltage at Q1 gate (ref to gnd)
voltage at both sides of R7 (ref to gnd)
792726d1573060711-amp-camp-pre-headphone-amp-acp-np-acp-2019-gif
Here are the values:
L channel 0.438 R Channel 0.419
Not sure which one so I measured these
r11 L channel 0 R channel 0
r12 L channel 0.07 R channel 0.027
r13 L channel 0.22 R channel 0.083
r14 L channel 0 R channel 0.001
r8 L channel 0.437 R channel 0.415
r10 L channel 0 R channel 0
r9 L channel 0 R channel 0.001
L channel 0.503 R channel 0.477
L channel 11.75 R channel 11.73
L channel 19.49 and 14.34 R channel 19.85 and 14.48
Balanced outputs for use with ACA momoblocks
Newbie question: How do balanced outputs/ inputs work and can these be retrofitted to ACA+? I read a review of ACA used as monoblocks and they mentioned the difference with the sound using the balance configuration?
More pictures attached here. Let me know if these are okay. Thank you for taking time helping.
to archishih #1133
Hello archishih,
Before I would exchange parts, I would reflow some solderjoints.
Especially around your Mosfets and the Optocoupler.
Reheat and add some solder.
On the pic from top I don't see the Mosfet -legs surrounded from solder?
Only some thoughts....🙄
Your caps are oriented right.
Your Optocoupler is oriented right (dot to dot).
Perhaps Mosfet N-channel Mosfet P-channel mistaken?
Greets
Dirk 😉
re-flow all solder joints at green power resistors, too
there must be cold solder somewhere, circuit an pcb being so straightforward
general remark - not that I didn't did same thing here and there (service job, so my mileage in this is different than regular Greedy Boy is having) but - I simply despise seeing pcb full with majority of parts augmented in size, vs. originally intended
stress which that is putting on all Vias is ridiculous, l lack of mileage resulting in not meticulously bent part wires, then increased difficulty of proper soldering of bad oriented legs in pads
recipe for disaster
and, in majority of cases , reason for oversize parts is "I read on forum that these XYZ parts are better than ZYX parts!"
best parts are those allowing that my thingie is operational
if in doubt, or you have a brilliant idea - ask thingie originator/constructor ...... don't just follow first dumba$$ on internet
ok, nuff with rant
been there, done that ........ made every imaginable audiophool mistake, and also some unimaginable, too
so, think I have some right to share bad experiences and point to bad habits
Reflowed those soldering points and some more. The measurement results are the same. If I have cold joints somewhere, wouldn't I have different measurement on two channels? Both channels behave the same make me think there are something else wrong applied to both channels. Anyway, thank you all for the help. I think I may not be able to get it to work.
