Amp Camp Pre+Headphone Amp - ACP+
As Zen Mod mentioned, those little switches are easy to destroy by applying too much heat for too long. The plastic melts, the contact alignment shifts, and the bedsheets are defecated. The cure is to do the soldering with the switch clamped in a vise in the easiest, most unobstructed possible position for soldering. Set it up so you can get the iron in quickly, get the solder in quickly, and with a clear view for the operator. Then get in, do the job, and get out. Wham, bam, thank you ma'am.
I don't have the version with the switch but looking at the pictures at the diyAudio Store, only two pins are used in the circuit. The other pin is not connected to the circuit, but the board provides a hole so that the switch can be mounted on the board.
Hi Adason,
How to bypass the switch?
You unsolder it from the switch, and you just solder together two wires which should be connected?
Besides, why do you have three wires there, two should be enough to turn it on? It looks to me you are shorting the plus to ground. No power supply likes it, smps can survive it, but still.
