Alpine 3553
Measure the DCV across the speaker terminals of each channel. Do you read more than a tiny fraction of a volt on either channel?
If so, which channel?
The thread says 3553 but the spike you posted says 3554. Which is it?
Have you done ANY work on the amp other than repairing a solder connection?
What I don’t like is that the ends of 3 parts are stripped and the copper is exposed.it is on voltage regulator.
Then I can put more solder, and solder them good, I tried to don’t touch each other as much as I could, also when the amplifier starts it stays red 1 2 seconds then it goes green , as far as protection goes. I don’t know what it should protect.
And I tested like this: rca signal on the bad channel , speaker output on good channel and the rca probe on the good channel.
So on cb connector on the motherboard I had just louder sound, not related to music , and on ic101 on exit it mutes all the sound if I remember right.
The solder that's there is garbage. It needs to be removed 100% and the connections resoldered. The connections should be uniform/symmetrical and have a profile somewhere between the shape of the two in the graphic below.
I don't understand post #35 or 36. You're going to have to be far more specific in the questions.
on 35: I tried to test the bad channel to see where the signal stops , touching the board in different points, if I had sound I know that the signal is ok till that point.let’s say other way : touching in different points will close the circuit thru a good channel.
And 36: on the picture there are 3 big marks separate of each other , how could I know if they have to touch each other(common) trace or separate.
What are you using to test for signal?
The darker areas are the bare board (fiberglass). The lighter areas are tinned copper circuit board with a green transparent solder mask. The gray areas inside the lighter areas are areas where the solder mask was not applied. You're seeing the solder that's tinning the board.
