I have both amps built and wired, less final exterior finish and final connections to FE board.
Starting the power up phase now.
Started with my 12vdc power supply. I had a jumper wrong and was getting 8vdc, made the change and now getting 12.3vdc.
I made some wrong assumptions early on and didn't think through some of my control circuit plans. I'm using the AMP.org board for the momentary switch. I planned on using my larger 12vdc power supply for this but with 3 relays and a timer the AMP board isn't designed for this load. So waiting on the small matching power supply board and parts to build it. Then the small transformer can bring on the larger power supply that supplies the fan, and timer and relays to drop out the MS35's.
I've bypassed the switch and using the variac to power on/off.
I have a small 5 amp variac to help.
First test up is the soft start (BTW I'm disconnection everything down stream of each step) relays engage, red led comes on and getting 117 v AC (same as wall outlet)
Next up is the transformer. I slowly increased power up to full voltage, no issue. Let it settle a few mins and I'm getting 38.7 v AC on the secondaries. Turned it back off, waited 5 mins, then switched it back on at full 117 volts, again no issue, soft start seems to be doing its job.
Then checked the power through the bridge rectifiers and getting -52.8 on one pair and +53.1 on the other pair.
Then after a couple min wait after power down I connected the 4ea 82,000 Rifa caps. Again, I slowly powered up with the variac, back up to the 117 volts, no issue. Powered down, waited 5 mins, then full on power via the variac switch.
I guess the soft start and slow charge circuits are working so far.
Now on to the DIY power supply board check.
See any issues yet?
