He have talked about a diy project with laterals here : https://www.diyaudio.com/community/threads/f5-power-amplifier.121228/page-834
Maybe we are not that far from a diy F7The lateral parts have lower transconductance but also lower temperature coefficients.
I do have a diy version using the Alfet laterals, scheduled for release this year.
Will this turn into a project for the Alfet giveaway?I have PC boards for an F5L, similar to F5M, but needless to say, more expensive...
Nelson, when you say more expensive - can you expand on that comment thanks.
Well that is certainly correct Vunce, then he made that comment before giving away 60 quads!!Just a guess, but probably because the output devises cost more than vertical mosfets.
So maybe not more expensive for 60 members around here.
Now to get hold of the pcb (gerbers) - any hints Mr Pass at this stage, or too early to ask?
That sounds awesome! 👏I have PC boards for an F5L, similar to F5M, but needless to say, more expensive...
- ALFET MOSFET give away (ALF08P16V + ALF08N16V / 2 pairs)
