Aleph-X builder's thread
Sorry if this has been asked.
The input is set up for balanced line. I have some equipment with balanced outputs but most of my stuff is unbalanced. For testing I shorted the - input to ground and just used the shield terminal and + inputs. If you set up the amp to use both, do you need to short the - input to ground when using RCA's? Seems like I got a hum without doing that.
Do you use a switch to ground it when going with an unbalanced source?
Thanks, Terry
wuffwaff said:
Hi Terry,
yes -IN needs to be grounded (via the same value of input cap you use on the +IN side).
You can either use a switch or shortign plugs between PIN 1 and 3 on your XLR inputs.
William
Not sure what you mean by the input cap. Could you explain a little more?
Where would I find shorting RCA's?
Thanks, Terry
Hi Terry,
to keep DC from entering the amp you need input capacitors in series with +IN and -IN. (around 10uF will do nicely).
To use the amp unbalanced you connect the -IN cap to ground.
You don´t need shorting RCA´s (wich are very easy to make yourself) but a shorting plug for the balanced input connectors or a switch that connects -IN to ground
William
wuffwaff said:
Hi Terry,
William
Do you mount those caps on the input jacks themselves?
Why would I use a shorting XLR? If I'm using a balanced input I wouldn't want to short the - input to ground would I? Or are you talking about a 1/4" jack that shorts when nothing is plugged in?
Thanks, Terry
The caps could mount directly to the jacks or anywhere convenient between the jacks and boards.
Only short the - input to ground when using unbalanced sources.
Depending on how you implimented it you have some choices:
An RCA to XLR adapter cable that shorts your - input
A switch to short the - inputs to ground when using the RCA jacks
An XLR plug that shorts the - input inserted into the jack when you use the RCA input.
If you use a rca to xlr adaptor which shorts the - signal to ground at the connector then the - input cap is short circuited since the signal and the dc will be routed to the gnd wire connection on the board.
So the -signal to ground connection should be after the input cap .
Ideally -signal----input cap----gnd---- -input pcb
however.... any gnd connection at the -input of the pcb will likely destabilise the dc balance carefully achieved by pulling one side to ground so destabilising the other side.The inputs are essentially floating with the dc balance of the x circuit.
Thanks, Terry
I've also been looking for a discrete circuit that can convert single-ended to differential with no DC offset. It seems that a servo'ed buffer will be necessary to avoid DC blocking caps since even a servo on the main amp cannot remove any DC sum between the + and - buffer outputs.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=65896
DRV134 buffer Burr Brown is one possible solution. Blocking capacitors are still recommended in the app note.
I think the easiest solution for the AX is a good balanced line transformer.
Might not be as cheap as a couple of chips but it is much simpler to implement and probably more transparent than any active solution.With a 1:2 ratio you could probably use a passive pre as well.
Otherwise just build a nice balanced tube or chip pre.For a simple but good tube one look at the Aikido which can output balanced as well
I have used the drv 134 on occasion and they are ok if you want the simplest pre/buffer.But... I would not add them to an existing pre.Too many stages for my liking.
Hi Protos,
I don't understand what you are saying. Are you saying that no matter what, the DC will be a problem when using unbalanced inputs?
I'm not sure where to ground the -input. Does it go to the star ground? I used a terminal block on the PCB for the input. For the test, I just ran a wire from the -input terminal to the one marked shield and then connected the shield on the shielded cable to the shield terminal as well, and the center wire to the +input terminal. It worked fine and was dead quiet. No hum at all. What is it that the "input cap" does and do I understand that there must be one between the -input and ground when using an unbalanced source? If these are necessary, why aren't they on the PCB?
Thanks, Terry
STOP,
let´s try to keep it simple.
There´s absolutely no problem using the Aleph-X with an unbalanced source! No need for opamps, drivers, transformers etc.
1. Connect the +IN and -IN from the circuit board with the XLR connector using two caps in series (around 10uF will do)
2. Connect the ground from the circuit board to PIN 1 at the XLR connector
Now the amp is ready for Balanced input signals.
When you want to use a unbalanced input:
1. Connect a RCA female plug parallel to PIN 1 (ground) and PIN 2 (+IN) of the XLR connector. After the cap, directly at the XLR connector!!
2. Connect ground (PIN 1) and -IN (PIN 3) at the xlr connector. You can do this with a switch, a shorting plug or a RCA to XLR adapter.
3. Connect your source to the RCA plug .
Ready
William
You can omit the caps if your source is absolutely DC free and has no output resistors to ground (like a BOSOZ).
Or you can adjust the dc balance with the preamp connected as Hugo did.
Hi William,
Thanks, that is much clearer. The only think that is confusinign to me is where you say, "Connect a RCA female plug parallel to PIN 1 (ground) and PIN 2 (+IN) of the XLR connector. After the cap, directly at the XLR connector!!"
"After the cap, directly at the XLR connector"
If I make the connection after the cap then the cap is not in the circuit. Is this right?
When you say XLR connector, are you talking about the XLR connection on the PCB or on the XLR socket?
I guess what I'm asking is, do I connect the wires coming from the RCA jack to the pins on the XLR socket or tie them in past the input caps?
I will us a switch to ground the -input to ground.
Thanks, Terry
wuffwaff said:
Terry,
connect the rca to the xlr socket, connect the switch to the xlr socket. Leave the caps in the citcuit all the time.
William (who is too lazy to make a drawing)
Perfect!
Hi Tom,
Thanks for the illustration. That is what I thought William meant but wasn't sure. You don't have the Input caps in yours though so without the explanation I still wouldn't have gotten it.
Thanks again,
Terry
