Aleph Jzm
@poseidonsvoice - :nod: :cheers:
For all - The software used to create the guides has a few idiosyncrasies. See step 8.
For those in "Full Screen" Mode, there will be separate tabs at the top of the 1st page in the guide. For those that are viewing in the "long form", they will be at the end of the guide. Pics below.
Full screen - 1st slide.
Long Form - At the end
Reactions: poseidonsvoice
^ Congratulations! Come on in, the water's fine.
Post if you need anything. If you haven't seen it yet, we've started a dedicated support thread for questions that may come up during your build (separate from your PSU). If anything is confusing / unclear in the build guide, feel free to post in that thread.
If you have questions re: a PSU, you can post here / in a thread dedicated to the PSU you choose / or start a thread. There are tons of ways to get some advice / help if needed.
Hi guys,just want to purchase one kit for stereo and my question is,if I go with Toshiba 2sj74 jfets,do I need to buy a matched octet of this P chanell jfets or is a quad enough for stereo set up,so that I use than only J1 and J2 populated on the board?Or Im wrong??
^ If you get the JFETs from the store (BL Toshiba), you only need a matched pair for each channel. Put them in J1 and J2 positions. Case 1
You CAN use a matched quad for each channel if you have them (any suffix). Case 2
See notes in upper left of schematic from the build guide pasted below.
