Aleph J-X Amp Project
4A on a 400VA sharing both channels.......you definitely need a bigger trafo. 600VA would be the bare minimum IMHO, but you should be OK with it.
Yeah, that's what it looks like, I first thought the buzzing was coming partly from my test speakers, but then I realized its all coming from the transformer itself.
Thanks for the help guys, I learned how to measure the bias current tonight! :up:
Coreyk
Try connecting one channel to the transformer you already have, to get an idea of the improvement you will get by going with a bigger one.
Yeah just disconnect one channel, and have a listen.
Let us know what you think
Did you try disconnecting one of the channels from the transformer.
Give it a go and let us know what you think?
From what I have read the mur860 diodes perform quite nicely. So I would stick with them since you already have them. You could add small heatsinks to them, although I think you can run them with out heat sinking (I am not sure though).
can I ask what amp you currently use and why you think you need so much power at 1 ohm?
The thing about diy is its a journey, try a couple of small amps and see if they work well, I would build a stock F5, probably more important is what is the speaker efficiency?
The worsst thing you can do is take on a project like you talking about and get disheartened, start simple.
Good luck.
Speaker currently - Ribbon 3 way hybrid /bi-amped 84 db 2.83 v /m
1.8 ohm 400-5 K 1 ohm 5-20 K
That is good advice.
If this will be your first amp, then build the F5. Heaps of people have built them and are still building them so there is heaps of support if you have problems.
Besides that it is a very easy amp to build, and sounds very good.
In fact it has become a favourite of many people now.
http://www.diyaudio.com/forums/pass-labs/121228-f5-power-amplifier.html
Yes i have looked at the F5, F4, Aleph -J , Alephj-X , not sure which would work for me , but I'm interested in getting my feet wet and playing with one ..
Hi a.wayne
You could also go with this http://www.diyaudio.com/forums/pass-labs/150653-burning-amplifier-ba-2-a.html
However no one has built it yet as far as I know (except for Nelson that is).
Have the schematics will take a look ....
Well I have my Aleph-J playing music right now, just powered it up about 40 mins ago, still warming up. I have a few questions
This Post need PIcs ...................🙂
Yeah, I made the changes, still buzzing, damn. It's gonna be a tight squeeze but I think I can shoehorn a 600va tranny in there.
edit - also after being powered up for a while the transformer is getting fairly warm too
Use a separate chassis for the Supply , i like to use 2 chassis and get the transformer away from the Main Board..
The problem is not finding an amplifier that will drive your speaker load to your requirements.
It is the cost involved to build it. I think you wanted as a bare minimum 160W into 1Ohm and 85W into 8Ohm.
Lets assume 85W average and 160W average.
You need 37 to 40 volt rails to get your 85W (170W pk) into 8 Ohms.
You need around 18A to drive 1Ohms to 160W (320W pk).
You will probably want around 6 to 8 A of bias current (for push pull topology).
Let us say 8A.
8A x (2x40) = 640W of heat per channel. the heatsinks will be huge something like 350mm long by 1200mm high per channel.
You will need something like 1.5kVA transformer per channel (as a bare minimum) in reality you probably want 3kVA per channel.
Capacitors probably, 2F per channel (thats 2,000,000 uF). You could probably do it with 1F if you use CLC but the inductor will be huge.
If you have that sought of money to spend I would probably spend $2000 on a new speaker design, and around $700 on the amp.
No it was 20 watt @ 8 ohm , 160 @ 1 ohm..
MEGA ,
I took a look at the A75 material ........ I likey ... off to more reading this just might be the one.... 🙂
Awayne,
An A-75 amp with 12 output devices per rail is a hulking monster. I know, I have one on my workbench right now. If it can not drive anything it will surely pull a train load of boxcars down the track.
Everyone who has built them has good things to say. I just with the boards I got were mono.
Tad
Haven't built it yet, but its one of the many projects on my plate, its Class A up to 75 watts, beyond that it goes into Class AB up to 150watts, and will drive into 1 ohm quite happily. The design is scalable i.e. you can up the voltages and add more outputs beyond stock. From what I've read on this board, the sound is very nice, though not as smooth and refined as Aleph (purely subjective of course). To get an Aleph to go properly into 1 ohm, it'll have to be physically gigantic or water-cooled, with many many outputs, big supply, big everything. There are some Pass designs that will work with 1 ohm, but not with a lot of power, the A75 is the closest amp here to my knowledge that meets your requirements. That being said, if you haven't built anything yet, I wouldn't recommend that as a first project, its a bit complex, and requires a fair amount of hardware. A good example: Pass DIY Gallery: A75 - Alain If your ambitious enough, anything is possible!
Take a look here: scroll down to A75
Pass DIY: Project Gallery
Go for it.
However, I would seriously consider getting your feet wet with an F5 first, even if it is only one channel.
Then go straight to the A75.
You will probably need to buy at least 100 (make it 200) n channel mosfets and at least 100 p channel mosfets to get them matched.
I would start up a new thread for this project so people can help you along the way. I will be glad to help in any way I can.
Enjoy the ride. Once you start you can't stop.
