Aleph J illustrated build guide
it's working ! it's working ! :rofl:
Measuring ripple is way easier than it sounds. Use your DMM, place the probes across the terminals of the cap (black to black, red to red) and set your meter to it's lowest AC voltage range. Most meters will have something like a 20mV range or lower. This is the one you want to use. Just make the reading - this is your amount of AC ripple on your PSU caps. You'll probably find something on the order of 1-10mV of AC ripple, depending on where you measure and your bias setting.
Measure it on the big white ones, then the smaller ones before your bank of parallel resistors (use the "input" leg of the resistors to measure after your second set of caps), then measure at the output of your CRC boards to see what the final ripple level is. You might find some interesting differences...
As for your last question, this is what I am going to experiment with for my Aleph-J. I have an outboard PSU that is configured as:
750VA toroid
Dual bridge rectifiers
39,000uF caps, 0R1 15w (5x 0R47 3w), 27,000uF for each rail
5-foot long 13ga Power umbilical cord
4x 39,000uF cap (one per rail, per channel) inside the (soon to be completed) Aleph-J
I also have a big pair of 10A 50R inductors that I want to play with. I would like to measure which works best: CRCLC, CLCRC, CCLC, CCRLC, etc. I have some playing around to do over the next few days...
Sorry, measurements need to be made with the power ON - so you also need to be CAREFUL! A slip of the probes will erupt in a shower of sparks... You also need to have the amp boards connected, so that the amp is pulling some juice through your PSU.
This is the only way to measure, but you need to work carefully and in a well-lit area so you can see what you are doing.
