Aleph J illustrated build guide
semi populated pic
Kevin here is a decent photo semi populated aleph J board. Hope it helps...
If you hold the ZTX's with the flat face towards you and the pins below, then the right hand pin is the collector, middle is base and the left is the emitter.
Do a search on google for images of the ZTX450 pinout (550 Is the same)
Thank you! I had done the Google searches and read some data sheets, but managed to overthink it and confuse myself with top vs bottom views. Turns out I had it right.
Well I've double checked everything, including resistor values, caps, checked for solder bridges, placements; absolutely everything and it still gave a big offset. 😡
So I had a good think and considered that the only difference with mine was that I've used equivalents for the bjt's because I didn't have enough ZTX450s. I used BC547C's, so I removed them and replaced just Q3 and Q4 with my last 2 ZTX450's and it worked!!!! 😡😡😡😡😡
So the lesson is that BC547 may look like an equivalent but it isn't.
Man did I curse.
ZTX450's on order, I'll update when I've fitted them and also replaced Q2 with ZTX550's
same channel again ?
It's happened on both channels, but I only changed the 2 BJT's on one channel, I left the other channel still faulty. No more ZTX's left. I do have BC547's so when I get home I can put them in Q3 and Q4 and see what happens, but I don't hold out much hope.
What is strange is that it works on my lash up for a short while, plays music,no screaming in my cheapo speakers, then the offset starts to climb and quickly gets to a high level.
Does one of the output devices get significantly hotter than the others? From afar it sounds like you may have an issue with the thermal connection to the heat sinks. As one or more devices heat up there is a thermal runaway.
I have an infra red thermometer and can read the temperatures at various points on the board and heat sinks. The IRFP240's are all at or about 52C and aren't running away.
I've not done any testing of the bjt's during the period when the amp is working, but after it failed they were all around 30C.
url], on Flickr
url], on Flickr
tHE 2 BOARDS ARE A SOFT START AND A DC BLOCKER.
Toroid is a 1KVA ( I had it in my stash)
Caps are 33,000uF 63V (also in my stash).
Rails are 25V
The 2 IRFP240's turned sideways, are mounted just in case I want to wire them in circuit at a later date.
url], on Flickr
url], on Flickr
Please bear in mind that this has been soldered and re-soldered many times and it is a lash up to test it.
Most of the resistors are 0.25W, others are 0.6W and the big ones are 5W because I had them.
I'm not using the LED's.
