Dale: Any new news on the heatsinks? 2 versus 4, etc ....... I've got my tools all ready ....... I want to start drilling!
Heat sinks
Actually,
I am looking at some of the extrusions at M&M metals.
http://www.mmmetals.com/pages/extrusion profiles/extrusion tables/Flatback 4 & up.htm
I am thinking of gettibng some quotes on the following:
MM519922 - 12.2"x7" - may only need two per chassis
MM513809 - 10.3"x8" - again, may only need two
and the Wayne model
MM11645 - 6.6 x8" will need four
Which look good to you guys?
Dale
I talked to Keith Mandell and they don't really like small orders, but will do it if in stock.
Actually,
and the Wayne model
Dale
Dale,
It's funny ..... I called Keith Mandell yesterday and discussed the exact items that you just mentioned.
We've discussed the following:
1. The two item # that you just posted requires a minimum order of couple thousand dollars.... there is none in stock .... so, we can pretty much forget about those two.
2. I I remember correctly, there is plenty in stock for the ones that Wayne uses. It will take about 2 weeks to get the order processed ..... cut it from a 8' extrusion, anolized etc and then ship to customer ...
3. When I spoke to Keith, he's very anxious to sell it to me - I did told him that I'm a hobbyist. I told him that we've a little discussion here and I'm not ready to order yet.
I say that we go with the in-stock stuff. We could spend way too many hours tracking down alternatives. I have a machine shop at work and I'll ask them if they know of a source before placing an order.
Heatsink height
Guys,
Suggestion on the heatsinks height ......
Assuming the width of the case to be 14" (includes heatsink fins), what should the height (vertical distance from the bottom plate) of the case or heatsink be for the amp to look good .... looking at it from the men's point of view? I'm thinking of ordering it in 12" height since it does not cost much more than 9" height.
Guys,
Dale,
John Snowden is a great guy. I stopped by Victoria Magnetics today to pick up a Leach Amp Chassis Kit for a friend, and talked to John for a bit. He does a great job on custom transformers.
I picked up my metal today. I picked up 4 - 9"x18" 1/8" thick and 4 - 9"x8" 1/8" thick 6061 aluminum for $86 including tax. The place I went to charged by the pound. They are called Metal Supermarkets, and are located near Atlanta GA.
My heatsinks are 8"x9"x2.6" and I am using 4 per chassis. My case dimensions including heatsinks are 8"H x 14"W x 18"D/
I should have my heatsinks tapped today for the screw holes, and start putting on the angled brackets to hold the panels on them.
It should come together quite nice. I thought I would have to use some U-channel under the transformer to support the weight, but the 1/8" 6061 aluminum does not really flex with the weight on it. I am suprised how thick 1/8" is. I was planning on using 1/4, but it looked too thick. For the front, I might get some 1/2" for the front later, but it would have cost me around $80 for the two front pieces, and I want to save the money for later.
I received more money orders in the mail today, and I will e-mail those who I have received payment from later tonight, along with an address confirmation.
Good luck with your chassis.
Brian
gte619j@prism.gatech.edu
Brian
I have not ordered all the parts yet for the boards but does anyone knows how big of a hole should I drill on the front plate to install the led? Thanks.
How are you mounting the LED? A plastic LED bezel, a brass bezel (recommended - looks cool), etc...
...... I have not given too much thoughts to the type of led to be used. Yes, I do want it to look "cool". So, how about part #, vendor and size of hole that you're using? Thanks.
I was just planning on sticking it through the hole sized measuring device that you use to measure what drill bit to use and drill the hole in the center of the finished case.
I have a lot of work until I get that done. I have my holes marked in the heatsinks, and the L brackets cut to size, and I will try to drill and tap the holes today. I will post pics of my progress this weekend.
I was planning of brushing the aluminum with very fine steel wool, and putting a very thin coat of clear coat on it, instead of the anodizing, and I can get it anodized later, should I have the cash. My heatsinks are clear anodized.
Brian
Brian
Brian: On a different subject here for the next 1 or 2 posts, did you use a 4 gang VR for your input and output volume control for your BOSOZ? Can I have the part #, vendor name and price? I can't find one, so I'm using (2) 2 gang VR for the volume control. Thanks.
For the BOSOZ:
I mounted the boards to a temporary chassis using metal standoffs. I hooked up the transformer to the power supply.
For the input and outputs, I have used no potentiometers. I just have it tied the inputs and outputs to RCA connectors for now. I have a dolby digital decoder that I use for the digital out of my cd player and the rca out from it. It has a remote and volume control. I am just going to use it for now, and get some fancy potentiometers later.
EDIT: Once I get my aleph done, I will change the rca outputs to the neutrix xlr connectors that I bought. I am going to make a dac next year, and will probably add potentiometers to the BOSOZ, or make a passive pre-amp.
Brian
Brian
I actually have it in an old black chassis now, with no top. I just drilled some holes in the side for rca and power.
It really isn't a large priority for me. I am working on my Aleph cases now.
Brian
Brian
brian could you please post a pic of one of your heatsinks drilled and tapped with no devices mounted so i can have a look.
I had a long day at work, and didn't have time to finish them. It will look like the pic in Wayne Sankey's gallery:
I will try to take pics on Friday. I left my stuff in Dr. Leach's audio lab, where I was working on it.
EDIT: I used 1/8" thick L brackets that are 1 1/4" x 1 1/4". I also ran them along the whole bottom of the chassis, as I want the most support for the bottom. I am just working on the bottom and heatsink sides now. I will use 1/16" thick .75 x .75 for the front and sides.
Brian
Brian
Brian: Since nobody asked ....... let me ...... are you laying out the output boards ..... using that same software? The main boards will be ready in a couple days ..... and it looks like your case will be ready by this weekend.
I just decided to do point to point wiring. I can't afford to get another set of boards made.
I might lay out some boards later on, but not for a while. I think that point to point wiring should suffice.
Brian
Brian
- Aleph 4 PCB Bulk Purchase
