Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
When I got my Scarlett Solo which is balanced it sounded better than my Khadas Tone Board to my ears. The bass and mid improved.
I also have this HiFiBerry DAC+ Pro XLR which I have not tested yet as I need to make some leads, it plugs into a RaspberryPi. It cost £55. It did not test that well, worse than the Solo.
The Audiophonics DAC for my AllInOne amp tests well, it has SE and balanced outputs so I will be able to compare them.
