Lucas_G.... AD727 or AD797?
You are right! AD797.
Firmware and drivers for HXMelody?
Can someone give advice on software support with these chinese brands? Do they write their own firmware and drivers (which could mean dodgy support for the long run), or do they use generic support with stuff written by the original manufacturers?
DAC's as tone controls
Its not an EQ thing, FR looks flat in virtually all modern dacs. People who work with dacs have some ideas about dacs in relation to perceived bass and or perceived brightness, but there is no peer reviewed published research on it otherwise you would already know all about it.
Then buy one a listen to it, why waste your time reading what people type about their perceptions here?
Money. Also hoping for a smaller DIY board I can use together with something like the ADSP-SC573 and put everything into the case of my Img STA-2000D
So it IS just a DAC issue? Does anyone know what can cause a perception of increased bass when it isn't actually increased?
Distortion. The Eval board measurements show significant LF distortion. Exactly which available DAC products have addressed this I have no idea.
TCD
TCD
Easily measurable bad design or what?
I'm not sure Scott, I was certainly scratching my head after viewing eval
board data sheet. But have seen other implementations that didn't have it.
TCD
The AK4499EQ utilizes the cheap modern high distortion delta-sigma modulation method. The abundant quantization error noise and high frequency harmonic transients generated cannot be brushed under the rug and will impact the audible range.
The electrical characteristics of CMOS devices are horrible for the task of processing audio signals.
Op-amps are ill-suited for I/V conversion and filtering. Why use crappy op-amps in nonindustrial artisanal approaches at all?
Any attempt at analysing such a strongly nonlinear abstruse system is simply ridiculous. I love the hypocrisy, spiritualism and wishful thinking in audio.
As far as I/V conversion is concerned. Nelson Pass designed a beautifully simple discrete solution a long time ago (for his once and only DAC). Why don't people use something similar?
I might print and frame this post for everytime I need a laugh. Contains the highest density of audiofool BS in a few sentances I have seen for a while.
Because the OP Z of the 4499 is so low and the current swing so high, these
grounded base / source, open loop I-V's will produce a huge amount of
distortion.
It is possible to do but to keep the distortion down to a reasonable amount
requires really large quiescent current running through the IP device.
TCD
distortion.
TCD
I see, Terry. Are there any IP device that would be up to the task?
- Digital Line Level
- AK4499EQ - Best DAC ever
