Sonny,
Please tell me, how and where do I connect to I2S in the new DAC?
Thank you.
BR, Vitali
Thank you.
BR, Vitali
Be prepared.. 😉
I had all of the OPS for this DAC (3 of them). The first discrete OPS that came out was a big step over the opamp OPS. I'm wondering how much of a step up the newer discrete is over the previous discrete OPS??
Let's find out
Do
Hi Sonny,
If I wanted to stack my two discrete OPS to enable me to use them both or compare, would it be too much for the DAC OP to drive without affecting performance?
Do
Do
Hi all
I will get back in contact with you all during the weekend with answers to you all.
BR
Sonny
BR
Sonny
While the old one is good and originally did not have issues and was satisfied..
Still, to be honest, there is no contest between the two.
We did not find any need to make direct comparisons..
(More than swap out in place, which took not more than a minute or so)
(And we did it repeatedly)
Ciao, George
Ciao, George
You are comparing the original discrete shield (that followed the opamp based shield) and the latest shield with the gain stage modules, right? BR, PerWhile the old one is good and originally did not have issues and was satisfied..
Ciao, George
Joseph, I remember you did some nice measurements of the first discrete output stage (AK4490 USB Dac with dsd support.). It would be interesting to see how the new one fares, could you run some analyses for us?
Yes, I could. I do actually have quite an amount of data about the new/old output stage, and new / old dac..
I do not have the direct comparison 'charts' referring exactly to your question, between the new /old stage on the same dac.
I'm also traveling, so can not have easy access right now. Next week..
I could tell my impression, but it will be much better with data..
Ciao, George
Ciao, George
Can you please make one post with all info about new DAC..
Hi all
BR
Sonny
This weekend?
After 150 to 200 hours of break in. Finally the dac with 4 gain stage xlr finally opened up.
Analog. Clean. Detailed. 3d. Truly hi end stuff. I spent so little time tweaking it. And it sounded very good already.
Great Dac Sonny.
Great Dac Sonny.
USB DAC V1.2 I2S port
I2S connector J8.
For using the I2S input we need to connect to the J8 10 pole IDC connector.
The Level is CMOS 3.3V
Pin 2,4,6,8,10 is GND.
pin 1 is a +3.3V which is also used for the Samplerate converter SRC4392.
If you choose to use the +3.3V please feed it through an ferritebead and a 10uF X7R capacitor to GND. it is aloevable to draw 75mA from the +3.3V on the J8 connector.
Pin 3 is SDOUT
Pin 5 is SDIN
Pin 7 is LRCK
Pin 9 is BCK
This I2S port run as a slave at up to 192KHz and 24Bit. So any source should supply this port with BCK and LRCK to get it functioning.
I2S connector J8.
Pin 3 is SDOUT
Pin 5 is SDIN
Pin 7 is LRCK
Pin 9 is BCK
Anyone can tell me the pinout for J3 and J4 on the new DAC OPS?
Do
Pin 1 is +5.5V or at least 5.2V
Pin 2, 4 is GND
Pin 3 is +15V
Pin 5 is -15V
Regarding stacking two OPS on to of the DAC is possible but the loading of the DAC will be to low and the sound signature of the DAC will change.
BR
Sonny
Great Dac Sonny.
I am glad that you like it.
BR
Sonny
USB DAC V1.2 mainboard spec.
Specification on the USB DAC mainboard.
- Powersupply: +5.5V 340mA, +15V 10mA, -15V 1mA.
- Samplerate converter SRC4392 on I2S, SPDIF RCA and Optical SPDIF
- Samplerate converter output is 192KHz 24Bit.
- I2S and RCA SPDIF to 192KHz 24 Bit.
- Optical to 96KHz and 24Bit
- USB to 384KHz 32bit and DOP 128
- USB is galvanic isolated and feed directly to AK4490
- All signals are reclocked
- FPGA for glue logic
- Own microcontroller for controlling different types of Volume control
- Optional control of preamp through FFC 30 pin connector.
- 3 SERCOM ports (SPI,I2C or UART per SERCOM), IR, encoder and 6 GPIO, +5, +3.3V through the DDC connector
- Firmware for using DAC with OLED display.
- Same formfactor as the USB DAC V1.0
Hi Sonny,
Will it do Native DSD up to 256?
Do
Hi. I have finally finished my DAC and it is outstanding. For the first time in some 35 years, my CDs sound better than my LPs - and that is no mean feat. Well done, Sonny!
Hi
Is there a message in this thread describing the interaction of the individual parts?
Which circuit boards do I need to achieve what?
To the explanation:
I have a music server with USB port. I'm looking for a DAC. I have both (HD)-PCM and DSD files.
Thank you!
To the explanation:
Thank you!
Windows driver.
Dropbox - XMOS-Stereo-USB-Audio-Class2-Driver-305C_v4.13.0.exe
Firmware upgrade guide:
Dropbox - Firmware upgrade guide.pdf
Firmware upgrade tool:
Dropbox - sam-ba_2.15.exe
Firmware for USB Audio DAC V1.2 with simple frontpanel:
Dropbox - SITO USB DAC V12 - Firmware - 20170921.bin
Firmware for USB Audio DAC V1.2 with OLED frontpanel:
Dropbox - Mirand Frontpanel - Firmware - 20170921.bin
https://www.dropbox.com/s/6nw39ktcfr8g1so/SITO USB DAC V12 - Firmware - 20170921.bin?dl=0
Hi Sonny,
The new DAC is really doing a fine job - the best I have ever heard! 🙂
The link to firmware for DAC with simple frontpanel is not working. I installed firmware for OLED panel and for DAC with OLED panel. Adjusting volume is shown on the display, but the DAC is running at 100 %, not responding to the adjustments. Any hints? 😕
All the best, Erik
- Vendor's Bazaar
- AK4490 USB Dac with dsd support.
