Thanks Sonny, I'll wait for the parcel from you.
I have one more question🙂
I accidentally deleted it from the USB stick received from you and from
computer this driver: Xmos-stereo-USB-Audio-Class2-driver-305C (v2.26.0)
I tried to get him out of here:
AK4490 USB Dac with dsd support – Discrete DIFF/SE shield, PCM Filter setting | Mirand Audio - Solidstate designs.
Can you please confirm that this driver on Mirand Audio - Solidstate designs is OK and has no problems?
JRiver runs Audio-Class2-driver-305C, but when I press the player, an error is always displayed.
I found that when I want to load in " xmosusbaudiost305C_dfuapp.exe " I always get a DLL error...
Thank you.
Best regards.
There is a new driver. I will find it and upload it.
Display is a display tech.
NHD-2.8-25664UCB2
But it is pure graphic display so you will need to make display functions for it.
Br
Sonny
NHD-2.8-25664UCB2
Br
Sonny
I'm going to watch the site when it's loaded.
Can I hope that until Monday this will happen?🙂
Thank you !
Windows driver.
Dropbox - XMOS-Stereo-USB-Audio-Class2-Driver-305C_v4.13.0.exe
Firmware upgrade guide:
Dropbox - Firmware upgrade guide.pdf
Firmware upgrade tool:
Dropbox - sam-ba_2.15.exe
Firmware for USB Audio DAC V1.2 with simple frontpanel:
Dropbox - SITO USB DAC V12 - Firmware - 20170921.bin
Firmware for USB Audio DAC V1.2 with OLED frontpanel:
Dropbox - Mirand Frontpanel - Firmware - 20170921.bin
https://www.dropbox.com/s/6nw39ktcfr8g1so/SITO USB DAC V12 - Firmware - 20170921.bin?dl=0
Windows driver.
sam-ba_2.15.exe
sam-ba_2.15.exe
Sonny,
Sent you an email on your mirand-audio id as your inbox was full. Can you please check and reply
Hi Sonny,
I want to do now Firmware for USB Audio DAC V1.2 with OLED frontpanel.
To make sure I understand correctly.
I do not need this for USB to RS232 converter cable?
Or do I need it?
Thank you.
Best regards.
Or do I need it?
Thank you.
Best regards.
if I connect with USBDACv1.1 to OLED frontpanel, will the volume be adjusted from the preamplifier?
In this case, do I remove the simple display?
Thank you.
Thank you.
Hi Sonny,
Yes, now I understand, I need it USB to RS232 converter cable.
Can you tell me how the wires (red-black-and-white) connect to the 3-pin plastic socket?
Thank you .
Thank you .
Unfortunately, I did not succeed 🙁
How is it right - first upgrade frontpanel OLED, second upgrade DAC?
Or vice versa?
Thank you.
Or vice versa?
Thank you.
Hi Sonnya. Are you saying that with the Firmware for the OLED display + display NHD-2.8-25664UCB2, we can still not see anything on the display, and that we need to do some more programming?
SB
SB
Yes I have just got home from Germany this evening.
I have the parts ready for your shipment.
Hi Sonny,
Now I understand, I need it to RS232 converter cable.
Can you tell me how do the wires (red-black-and-white) connect to the 3 connectors plastic socket?
When I want to upgrade to a simple front panel for the new DAC V1.1, where does the plug connect the USB to RS232 converter cable? (J12 or J13? )
Or are I wrong?
Please be to help me, I have tried in many ways and now I can not adjust the volume to the simple panel 🙁
Thank you.
Best regards.
Or are I wrong?
Thank you.
Best regards.
Hi Sonny,
Any update on the shipping.
Can you send me the soft start and speaker protection modules first so I can finish my amp. You can send the dac later when you finish it.
HI everyone,
i'm listening to the new output stage and it's really amazing!!!
Nice work Mr. Sonny!!!
Keep on rockin'
Keep on rockin'
Hi, the shipping labels are generated..
We are waiting on DHL to pick them up.
Good you like it factory2nd. We can do a variant of the gain modules to be a power amplifier module in the range of 50 - 80Watt.
BR
Sonny
BR
Sonny
- Vendor's Bazaar
- AK4490 USB Dac with dsd support.
