ACA illustrated build guide
Starting at steps 44 of the illustrated build guide, IIRC
Step 44 for balanced input mode, using an XLR input ( clearly the preferred option), and 46 for single ended with external resistively loaded jumper.
Note, I think Jim had mentioned the connection error in Step 48 photo - i.e. the jumper should be connected to left channel black speaker post - but it looks like the photo has not yet been revised?
Thanks! There it is. I could not remember of the existance of the build guide in the store.... Any risk in connecting wrong as in the picture?
aca mono block help
hi ive had a look at the build of the bridged aca mono block and as a newbe ime a bit confused how to wire up, i dont have a kit like shown as i make my own enclosures, at the mo just heatsinks and pcbs ect as i want to have a quick listen bfore i commit to building it,, can you look at the two attachments and see if either of those wire ups would work please thanks alot
Finished the build in one long evening, had a blast! Abit finnicky the bias setting, maybe a 40 turn pot would be better?
I really love the sound, ready to sell my old amp😉
I wanna build a full size one, torn between f5 and aleph j .. any tips?🙂
4 Ohm speakers, medium sensitivity
In this case, I would highly recommend building a pair of ACAmps as mono blocks. Try both bridged and parallel. There has been some discussion of this in the ACA amp with premium parts thread. For lower impedance speakers, the parallel mono blocks are probably preferred, but as always let your ears decide.
Good news! The backordered parts for making the ACA kits have arrived so if you didn’t get in on the last buy you can just order them from the store. We already have some in stock and more will arrive very soon! If the store accepts your order then the parts kit will be mailed right away. However the chassis probably won’t arrive until the second week of December. If the store doesn’t accept your order then try a day later....
The kits make a fine Christmas gift for various nieces and nephews and children if you then sit down with them to help them build it. i’ve helped two 8 year olds build amps and their sharp eyes and coordination helps them catch on to soldering quickly!
And if you’ve been good this year you deserve such a great gift for yourself, and no doubt your wife will be happy to hear that there is something you really want. And can order it yourself!
LED question
I have the previous version monoblock pair. I'd like to get some different colored LEDs. I went to parts express and found this
Ultra-Bright Blue 5mm LED 5500 mcd
I don't really know if the forward voltage... is right. Anyone have any specs for which LEDs would work? I did damage one of the LEDs on one of the monos and found a spare in one of my parts drawers and it had no markings. I tested it and it worked fine (green) now I have one amp with a red and another with a (brighter) green.
rule of thumb for series resistor , at least good for start and you'll not burn the LED - 1K per each rail volt - go for first higher standard value than calculated
you can freely use even 1K5 with nowadays bright LEDs .... and sometimes you need even more
so , in few steps , you'll get it right
and yes - avoid ultra bright ...... you need nidicolous low currents for these
Hi, I just started the kit (most recent version as of 8/19)and am running into some mild confusion on the resistors and their locations- I see snippets of a Parts list in some of the assembly videos / pictorials in the forum but I didn't seem to get the link or this document that identifies the resistor value by its board location. Is there a link to his document / parts list that I can access?
thanks
