About possible Babelfish J interest
Most of these resistors are very conservatively rated. Unless a position calling for 1 watt, 3 watt, 5 watt and so on 1/4 is usually adequate, sometimes 1/8 watt. But for better sleep....My F5 boards from Peter Daniels required standing up soldier style (which I did) anything over 1/8 watt.
Russellc
@Russel, thanks for the tip, will take it into account when soldering resistors.
Hey ZM, any news on psu schematics ?? 😀
Anyways, started stuffing the board and noticed small mismatch between Q5 transistors you've sent (BC546) and labels that are attached (BC556) - see photo. Let me know if it still OK to go with it.
ok, just noticed the size, it's not gonna work unless i buy microscope 🙂
Few questions:
1) In case using only base PCB, I should only connect AD-AS, instead of N1-N2 right?
2) Is there a good reason placing transformers in front of the case and wiring through the bottom baseplate? Looks easier to have them in the back with less wiring.
