Don't worry, I have successfully used these kapton discs in my Aleph5 clone. The pads are also fine for the AB100 .Does it matter using thermal paste vs. thermal pads?
Have a look at my test for heat sink mounting, if you like:using thermal paste vs. thermal pads?
https://www.diyaudio.com/community/...mal-electric-conductivity.376934/post-6789894
AB100 boards are done, except soldering in the output transistors, but I am going to wait until all the holes are drilled and tapped in the heatsink before doing that.
Transformers are Toroidy 250VA PRI 2x115v SEC 2x32v, with two separate mono cases, no soft start required, simple 15 amp switch, no speaker protection circuit. As basic and straight forward as possible. Going against the grain with no anti ringing snubbers based on my interpretation of Tom C's notes on his web site of their necessity.
Any thoughts on how you would lay this out?
Didn't show the front mounted on/off push button switch or the little ground loop break circuit board.
Thank you,
David.
Thank you,
David.
David, I always try to put the transformers in the front of the amp, away from the boards, input and output.AB100 boards are done, except soldering in the output transistors, but I am going to wait until all the holes are drilled and tapped in the heatsink before doing that.
Thank you,
David.
Hi Could you please help with this info..Can the transistors KSA1381 & KSC3503 replaced with MJE350 & MJE340 respectively ??
So I know your looking for definitive answers but I looked at the 1381 vs 350 and assuming the compliments are very close. Everything matches up except one that might be critical. The power dissipation of the MJEs is 20W where the KSA series is only 7W. Now if the circuit is not pushing that transistor very hard and they are heatsinked then probably ok. You'll have to see how loaded that driver is though to know for sure.
You need to test stability by yourself.Hi Could you please help with this info..
Do you have an oscilloscope?
Use one pair output only when first test.
Keep input signal low,use a bulb tester in series with the main voltage.
Mje are slow devices when ksa ksc are fast low capacitance drivers.
Hello DaveFred
Great build progress well done .. I have the Gerbers for the AB100 power amplifier but just noticed that lovely PSU that you have as well
Can I purchase the Gerbers or point be in the right direction to purchase the bare PCB's if possible
this would be greatly appreciated
regards
regards
Thank you sir..You need to test stability by yourself.
No Oscilloscope..shall test test it by working itself..You need to test stability by yourself.
... but just noticed that lovely PSU that you have as well
Can I purchase the Gerbers or point be in the right direction to purchase the bare PCB's if possible...
The PSU is one I drew up myself and might not be ready for prime time as this is the first time I have used it, it is just elements I took from a number of published designs. I hope I did it right, time will tell...
Take a look at any of the PSUs by Prazi, I think you will be safer with those.
Transistors all mounted on heat sink and soldered in, starting lock things in...
(P.S., I hope I am not annoying the more serious crowd with all my pics, I scoured looking for pics when doing the build and didn't find enough, so I hope this helps other visual learners...)
- AB100 Class AB Power Amplifier
