AB100 Class AB Power Amplifier
Tnx Prasi for nice board, in NP original board R35 was omitted, maybe you can consider the input C to be film cap - 2uf2 or 3uf3? and maybe use some to 126 for bias generator ? nice board anyway.tnx.
That would be really great. Both suggestions... And maybe allow the 100uF-caps to be 12,5mm in diameter so that they could be my favorites (UBX as polarized and UES or RFS in feedback). Thanks for the board anyway :)!
Edit says they're in 13mm already as it's printed on the board. Sorry, I should have put my glasses on :D.
In my "cave man" diy AB 100 pcb i also bypassed all el. capacitors with the film ones :cheers:
Thanks osscar,
here are all the files...
regards
prasi
  • gerbers-AB-100 TO-247-R1-4CAPS_2020-04-18.zip
  • gerbers-AB-100 TO-247-R1-2CAPS_2020-04-18.zip
  • AB-100 TO-247-R1-4CAPS-top-silk.pdf
  • AB-100 TO-247-R1-4CAPS-stuffing guide.pdf
  • AB-100 TO-247-R1-4CAPS-sch.pdf
  • AB-100 TO-247-R1-4CAPS-bot-cu.pdf
  • AB-100 TO-247-R1-2CAPS-top-silk.pdf
  • AB-100 TO-247-R1-2CAPS-stuffing guide.pdf
  • AB-100 TO-247-R1-2CAPS-sch.pdf
  • AB-100 TO-247-R1-2CAPS-bot-cu.pdf
Reactions: 1 user
