I still can not get to work emu usb 0404 sound-card under windows 10 (beta driver does not work - it freezes my computer - it's time to buy something new ...) ... hope someone will build this and measure the harmonic spectrum correctly. The amplifier works still perfectly - low frequencies are great ... and other frequencies also satisfy me. Bias / offset very stable also.
Yes i agree - these will fit for 60V rails ! What transistors would you place in VA stage? I measured in LT spice - bd140 / 139 gives a little lower 2H than MJE 340/350, although the total THD is the same almost at bias 50mA per output transistor and 1W output at 1 an 10 Khz (my LT spice and real "amp" amplifier have a reduced gain from original article ).
I throw them in spice - seems works fine - reduced second harmonic, no oscillation.
.MODEL Q2SA1930 PNP(
+ IS=10.000E-15
+ BF=210
+ VAF=78
+ IKF=10.000E-3
+ XTB=1.5
+ BR=.1001
+ VAR=100
+ IKR=10.000E-3
+ ISC=10.000E-15
+ CJE=3.252E-12
+ CJC=63.196E-12
+ MJC=.33333
+ TF=83.239E-12
+ XTF=10
+ VTF=10
+ ITF=1)
.MODEL Q2SC5171 NPN(
+ IS=10.000E-15
+ BF=210
+ VAF=100
+ IKF=10.000E-3
+ XTB=1.5
+ BR=.1001
+ VAR=100
+ IKR=10.000E-3
+ ISC=10.000E-15
+ CJE=2.0000E-12
+ CJC=38.866E-12
+ MJC=.33333
+ TF=83.239E-12
+ XTF=10
+ VTF=10
+ ITF=1)
+ IS=10.000E-15
+ BF=210
+ VAF=78
+ IKF=10.000E-3
+ XTB=1.5
+ BR=.1001
+ VAR=100
+ IKR=10.000E-3
+ ISC=10.000E-15
+ CJE=3.252E-12
+ CJC=63.196E-12
+ MJC=.33333
+ TF=83.239E-12
+ XTF=10
+ VTF=10
+ ITF=1)
+ IS=10.000E-15
+ BF=210
+ VAF=100
+ IKF=10.000E-3
+ XTB=1.5
+ BR=.1001
+ VAR=100
+ IKR=10.000E-3
+ ISC=10.000E-15
+ CJE=2.0000E-12
+ CJC=38.866E-12
+ MJC=.33333
+ TF=83.239E-12
+ XTF=10
+ VTF=10
+ ITF=1)
+ IS=10.000E-15
+ BF=210
+ VAF=78
+ IKF=10.000E-3
+ XTB=1.5
+ BR=.1001
+ VAR=100
+ IKR=10.000E-3
+ ISC=10.000E-15
+ CJE=3.252E-12
+ CJC=63.196E-12
+ MJC=.33333
+ TF=83.239E-12
+ XTF=10
+ VTF=10
+ ITF=1)
+ IS=10.000E-15
+ BF=210
+ VAF=100
+ IKF=10.000E-3
+ XTB=1.5
+ BR=.1001
+ VAR=100
+ IKR=10.000E-3
+ ISC=10.000E-15
+ CJE=2.0000E-12
+ CJC=38.866E-12
+ MJC=.33333
+ TF=83.239E-12
+ XTF=10
+ VTF=10
+ ITF=1)
Thank you oscar. I am a newb and have not learned to use simulators. I really appreciate your help.
DOGC-H amplifier by Dr. Borivoje Jagodic -pcb
Please send pcb format in pdf of DOGC-H amplifier by Dr. Borivoje Jagodic
I recommend you DOGC-H amplifier by Dr. Borivoje Jagodic. It uses current-dumping topology. It is class AC and sounds very good! (better than class AB amps). If you want PCB, PM me and I will send you PCB in Eagle format.
- AB100 Class AB Power Amplifier
