A New Take on the Classic Pass Labs D1 with an ESS Dac
Hi Pidesd,
You are absolutely correct about the transconductance of the fet dropping drastically at low current, and after quite a few simulations, it looks like the fet plays a smaller role than I initially assumed. I need to verify this with real tests, so I'll be doing that over next week. If anyone has any favorites, let me know and I'll include them in the test. Here's the short list:
Owen
How about the Lovoltech LU1014D Jfet, I've been interested in trying this for a while?
Sean
wow, so after I go ahead and sort out another output stage and buy PCBs this becomes an option again. I had all but written you off mate. hope you managed to come through whatever was taking your time well and without too many bruises. man, now I gotta make some hard decisions
oh and SMD all the way except for main films, perhaps we could get a GB together for some high quality R's from elfa or firstronics? yeah stuff it, i'm gonna build this up as well. ok mate bring it on!! :evil: (<~dont know if thats gonna work) at least I have pretty much got enough films already for the job.
LOL, that took me all of 7 mins to convince myself I needed to build both up and use my favorite for the ackodac and the other for my workshop rig driving active monitors from a PCM1794A dac. this stuff is truly like a drug
Hi Owen, thanks for the reply.
I actually scan a few mosfet listed in Farnell and looking at the transconductance curve trying to find the highest Gfs around 10mA. But only few datasheet show the curve and even fewer show value at 10mA.
Here is a few I found and I actually order a couple to try.
2sk2989 Toshiba
ssm3k02t
cph3430 Sanyo
irfl014n
fqp2n60c
irlml2803
zxm61n03f
Some of those is smd, but the D1 bias current is only around 10mA.
BTW, I tried the 2sk216 and irf610, both sound very good.
...chuck
Hi Owen, any more movement mate?? sounding like I'll have to build up the QVR08's first and hope you get this done sometime soon. was hoping to get the parts with my next digikey order this week to save on shipping. i'll just wait for the official BOM though. suppose I could get some of the likely subjects while i'm there, though without knowing whether i'm ordering for throughhole or SMD complicates matters. any chance yo could incorporate pads for both in some positions for flexibility? I know peranders of sjostromaudio does this with most of his projects and I have found it to be very useful.
Hi Regal,
Sorry for the late response. I've attached a schematic that will work well with DAC's requiring 2.5V at the output.
Ignore the 33k3 value for R11 and R12, what you need there is a 50k pot. Start about midway (25K) and adjust to obtain 2.5VDC at the source of the fet. When that is set, you should see very close to 9VDC at the drain.
I'm not sure how much gain you need, but if you tell me what DAC and what configuration you plan to run, then I can dial in R1, R2, R3 and R4 to get you whatever you want voltage-wise at the output.
This project has been put aside for the past few months, but I should be getting back to it shortly.
Owen
Hi
would you please confirm that this schematic work with IRF610
I will use It with pcm63
Personally, I have no problem being patient, and I will do that. In my opinion, if one is impatient, they can work on the problems at hand and volunteer to help with the development. I've done a GB myself and I was amazed at how much work it ended up being. Mine was a simple machined part, never mind a complicated electronics development project. This one will without a doubt take some time.
I have been patient (this has been happening for 4 months now and thats just since this thread was started, all i'm saying is that due to the lack of communication and seeming slowed/stalled development, I have to go another way. I understand owen has a life and that he iust doing this probably for himself but sharing with the community, but I suggest he updates the thread with some real and accurate information on what is going on; if that info is that he simply does not have the time at the moment because of other commitments, thats perfectly fine, but periodically popping up and saying he hasnt forgotten about it and that the project is moving forward; and then promptly disappearing again is frustrating me. I repeat my well wishes and hope you get through whatever is taking your time well owen. if you get this finished i'll reassess the sutuation then, but I think the build I have undertaken to replace this in the ackodac output stage is going to be pretty amazing and my second option is a PTFE borbely active I/V
opc
Joined 2004
Hi Guys,
Looks like a few people are getting restless here, so I figured I had better pop in. Sorry for the long time away, I've shelved this project as I await the arrival of the Buffalo II DAC I purchased. It won't be in until March 15th, and I'm hoping to have boards done shortly thereafter.
As for development status, I've attached what I consider to be the final product in its best possible form. It's what I'm using now, and It's good enough that I'm done playing with it.
You can feel free to build it with almost any mosfet you choose, and it will work very well, but I suggest larger, higher current fets as that was the only trend which consistently measured better. IRF540's work perfectly, so do FQA46N15's. My personal favorite, and the best measuring device is the lateral ACD101NDD if you can get your hands on it. I rolled ten different matched sets of fets in and out of this stage, and most measured so closely that the difference wasn't worth worrying about.
I've foregone the entire B1 buffer section, so you now have only one gain stage/device. The output impedance is about 185 ohms which is better than the B1 anyhow. Fewer parts, better performance, better sound, lower cost. This circuit is really only for balanced use, if you want SE, use an op-amp as a diff to SE converter, or a transformer.
You can toss this together on a piece of veroboard in an hour, and give it a listen. No need to wait for a PCB, although one is coming.
I really enjoy it, it's one of my favorite little circuits. Please excuse the hand drawn schematic...
qusp,
I'm sorry that you feel I let you down, but you really need to have a little more appreciation for the amount of work that goes into this stuff, and the fact that your attitude in the last two posts makes an already thankless effort all the more daunting. I posted this circuit here so that people would give it a try, enjoy it, and hopefully give me feedback on what they thought of it. If you want a polished finished product, delivered in a timely manner, then there's a hi-fi dealer in your area that would love to take a few grand off your hands and give you just that.
I do this for fun, and I share what I do in the hopes that someone, somewhere will be able to take it and run with it. I've always got half a dozen projects on the go, some of them many years old, and a life that will always take priority. For the past month this has taken a back seat, plain and simple.
I suggest you try the new circuit, I think you'll like it. It's easy to put together on a prototype board, it costs next to nothing, and you can have the enjoyment of a funny looking prototype while you wait for PCB's. If you chose to use another I/V stage, then that's fine with me.
Owen
Hi Owen, great work and thanks for posting your finding and esp. your circuit.
Sorry if I had some questions, I had thought that the drain resistor (185R) determines the I/V gain and source resistor (400R) set the bias current (guess I am wrong). So how to calculate the output voltage to be 2Vrms for this?
I have a dac with only 1.2ma current and just follow original D1 circuit but use 2K for drain resistor to have reasonable output.
Thanks.
Thanks alot for sharing Owen,
I tried the circuit you posted on the first page with my buffalo DAC with great result.
I also have a question,
Without the dac attached, I adjusted the trimpots to read 0V, measured between the input and ground. Is this correct or should I adjust to 1.65V between input and ground?
Thanks again for your work!
Owen, no I totally understand how much work goes into it, i'm undertaking my own design for a portable output stage for the buffalo II (just for myself and first time i've ever taken anything like this on; yes i'm a bad headphone geek), I have the buffalo32 I and i'm sure version 2 will be great. all the same I chose it for the portable only because of the simplified requirements for different regulated voltages which makes it much more workable for a battery supply, I am going ahead with the ackodac for home, because I feel it is a better option personally and I like to have some input and feeling of DIY, the TP gear is great dont get me wrong, but its not very DIY IMO
no I dont feel let down mate, you misunderstand me, I simply couldnt hang on waiting when it was clear that it wasnt going ahead as planned. and thats totally cool with me mate, as others have mentioned this is out of your own time and the repayment you would get for the boards would be unlikely to even make a dent in the time put in to design and support it. just when you made such a large decision, it would have been nice if you let those waiting in on it, it happened before for personal reasons and then it looked like you had disappeared again. as you know from my earlier posts in the thread I had other plans as well and I simply decided to go ahead with them because they were a known quantity.
so thanks mate, i'll keep an eye on it, but its not quite so appealing anymore
good luck with it, i'm sure it will sound as good as it looks. likely you'll get more on the pre-order as well this way
oh hell, you know now that schematic is there and the fact I have most of the parts means that I will likely knock it up ;) but to make it any kind ofpermanant solution I w0ould have to get your permission to get my own PCBs made, the fact its now going to be for tghe B32V2 means pin headers are nolonger a possibility and my build 'm tring to keep everything well integrated and short as short interconnections. so perhaps it is best if I knock it up on proto, will let you know if I do.
please dont take this as me not being thankful for your time, that was never my intention
Hi Owen,
great job. I am curious, you originally had a different FET shown. Did you make your final selection based on the sound quality or just electrical performance? Was it just coincidence that the best measuring was also the best sounding?
I am building a very similar I/V, but was planning to use the original IRF610. Now I may try a few of the other devices.
Do you think the sonic differences between FETs is worth experimenting with? or in your experience do they all sound about the same?
Thanks!
opc
Joined 2004
Hi Guys,
ChuckT: This circuit won't give you the gain you'll need with such low current output from the DAC. I can run a simulation later tonight and let you know what the best values would be. If i were you, I'd settle on less gain to get maybe 1 VRMS since you probably have more gain than you need later on. I'll get back to you.
Yunick: I did mine by adjusting to 1.65V with no dac, then attaching the DAC and re-adjusting to make sure. This reference depends on the DAC of course, so consult the datasheet for the correct value. Some of the TI DACs want to see 2.5V there.
qusp: That's the spirit... it's so simple that you might as well give it a shot. If you want to simplify it further, you can omit the 0.01 and 0.0027 caps for initial testing. I would suggest using them in the final version however.
Jmertz: I ditched the original fets mostly because nobody seemed to like using the odd pinout/footprint. They also ran very hot because they were so small. As for sound quality, we're treading into dangerous waters. The measured differences are somewhere in the range of -102dB and -107dB THD+N. I personally don't believe that anyone could reliably identify one fet from another, but I'm sure others would argue that. I think the perceived difference had to do with the better temp stability of the larger parts, and I was probably biased by whet I knew was the best measuring devices.
It would be fun and easy to do a blind shootout, but I'm not the one to do it.
Owen
Hi Guys!
Owen
Thanks for your reply Owen,
I will rebuild my I/V to your new schematic and adjust for 1.65V at the input.
Thanks again,
Best Regards
David
