A guide to building the Pass F4 amplifier
Because that widget is an "impedance interface," (whihc really means "tube tone effects box") I bet there is a pot somewhere not-normal to change the operating point and therefore output impedance, thereby having a big inpact of the sound without large gain swings.
Thank you all for the advice.
The thing is that I´ve been using the BBA with a First Watt F5 clone (now in rebuilding process) and I liked the combination a lot (my other amp is a Leben CS-300). Actually I preferred the BBA+F5 vs the Leben.
My setting with the BBA driving the F5 was: Gain at 11 and Volume at 9.
As I´d like to build an F4, and this has no gain like the F5, my concern is if the BBA might or not might be a good match.
Thank you again.
Daniel
Hello guys,
I am gathering the materials to build the F4, I will be using this power supply (the one from diyAudio Store used for the build in this thread) and I have a doubt about the line input capacitor that is shown in this picture:
It is the small blue cap across the power input lines. I am not sure about it's value, is it 0.0033uF 120v? or something different? Any help will be appreciated.
Thank you.
P.
