900W H-class PA Amp with Limiter
just a BTW addition I now use a 6VA rated transformer for the stereo protection circuit and with longer use the small transformer is getting quite warm on the border of hot , so maybe this protection board needs say 12VA , and I don't have fans attached to the protection board with fans probably the 6VA transformer would be way too small.
6VA 12Vac is 500mAac rated.
that allows a maximum continous DC current of around 250mAdc.
For cool operation de-rate to about 50%, i.e <130mAdc continuous.
But very small transformer are usually designed that they run hot even when supplying no current.
Check to see how hot it runs when the load is disconnected.
Prepare to build H900 with uC protection and ethernet interface to diagnostics.
Transformer has power about 3500VA and 8 x 38V AC (power is measured)
