900W H-class PA Amp with Limiter
hi apex sir.
is this edited pcb correct?
so not wasting copper.
Mile hello! Build H900 to work without limiting the 3600w 2ohms and made the following modifications:
1k resistor R15-R16 680R to ally overwritten with VAS.
6 IRF2807 mosfets used in + ve 6 mosfets irf2807 in-v.
I used 16 and 16 2SA1943 2SC5200 the outputs.
overwritten by resistor 0R33 -> 0R47
4 x 100v capacitor 12000UF
Trafo 40 40 0 ​​40 40 - 4,5 KVA got 2000w without distortion. Above distorts a lot.
I want to put trafo 50 50 0 50 50 for 3600wrms. What modifications made?
The vertex with 16 pairs of works 5000wrms 5200 1943 at 2 ohms? The scheme works provided that Mr.? Thank mile.
