7193/2C22 to 12AU7 conversion Help?
Hello again,
After lot of trial setups, finally I have narrowed my gear as budget 300B SET(Chinese) as final stage/Power AMP feeding with a Parasound Preamp (200Pre).
All I can say is there is a good difference in the tube sound compared my previous Class D Leema Elements. And I love this difference and I am keeping it.😬
So this SET has 2x 6SN7 as Front stage which I might consider rolling to the aforementioned tubes by @andyjevans i.e. CV6 or 7193 depending on the sound signature I want.
Current tubes are probably Chinese makes and finds it to be a little bit shrill sounding on some tracks. Main 300b tubes are psvanes.
I would like to get a sound signature with bit of warmth and a little added bass. I normally prefer warmer sound than shrill and sharp.
So out of the two tubes mentioned on this thread such as 7196 and CV6, which would be suitable for my target sound signature ?
~RJ
Oh ok. CV6 were expensive when I checked last time :scratch1:. Not sure the difference would be justified for the paid price. I have heard even same tube types from different manufacturers sounds different too.
So this is a mess all in all.
These are the 6SN7s I like...
Reactions: RUSSELJ
My current PP 300B amplifier has a cylindrical plate 76 voltage amp direct coupled to a long tale pair 6N7 driving the 300Bs. I find the sound really good. The 6N7 have cylindrical plates that are slightly squashed into ovals. The 6N7 gets no love from audiophiles and the 76 hasn't really been heard from since Bruce Berman's preamp article in Sound Practices.
My PP HY69 (triode connected) amp uses a 1950s TungSol 5687 voltage amp direct coupled to oval plate National Union 6F8Gs as a LTP. It is hard to choose between these two great amplifiers,
Reactions: directdriver
Coincidentally when I found out round plate small signal triodes offer the most pleasing sound to ME, I also found out one of the most expensive 6SN7s happens to be the ink-glassed Tungsol 6SN7 with round plates. Therefore, I try to use 6J5 (or its predecessors such as 27, 37, 56, 76, 6P5, etc...) whenever possible at a much cheaper price. Western Electric tubes like 262 and 347 with round mesh plates are great but their currently exorbitant price is out of reach for me and many others.
I’m very partial to the 6J5’s also. This is my daily driver when it’s too warm for the OTL’s. Also the Freya with 6F8G’s. Don’t want to pollute the thread further. Carry on😬
Reactions: RUSSELJ
Hello there,
Just new in here..
I currently have a Douk Audio Dual-Tube Preamp which has a B9A base, where both the sockets are close to each other as shown in the Pic.
So my concerns are :-
1st of all is it even technically possible to roll the tubes to the 7193 ? If so then it should be 7193 tube for each channel i.e. a total of 2 tubes would be sufficient ? Or i will need dual for each channel so a quad setup ?
Regards.
~R
I just received the same one. The T8 Pro. It states it can use 6sn7 tubes but it needs an adapter to use. Now my question is. Does it need the 12.6v or 6.3v version of the 6sn7 to 12au7 adapter?
I also reached out to Douk audio to ask and waiting for response.
