7" Lilliput LCD Projector/400w HQI Bulb from the UK (Midlands)
helps if i add the picture 😛
Well thats one problem sorted nick 🙂
As for the other fan placement, I would suggest relocating your ballast to behind the mirror...it looks like you could make it fit, might need to relocate the mirror a little more forward towards the lcd, but that wouldnt be a problem mate 🙂 Then you can whack ya fans in where the ballast is currently fixed in your projector now 🙂
Hope this might be of some help for you bud ...
not overly hot it does get warm, but that isn't an issue if it was behind the mirror, I gather you will be mounting the control panel from the lcd there also? If so it wont be an issue with the heat...moving it will open up the area prior to the lcd for the addition of fans mate 🙂 and believe me with that 400 watt you will need them lol...
As you have seen on my PJ nick I use the 2x120mm fans running on approx 1/2 speed and they work extremely well...I think one blowing air across the light path (where you currently have those 2x80mm fans) and moving the ballast to before mentioned location would probably be your best bet (running full speed) other than using a cold mirror of course. (unfortuneatly this wasn't an option for myself as cold mirrors aint available in OZ!) Purhaps you could try one though nick, place it after your condensor 🙂 Good luck with it anyways bud, eagerley awaiting more shots of the progress mate, keep up the good work 🙂
I read your post about you being able to keep your finger next to the condenser for 30 secs so yuor cooling must be good 😛
what would you say to putting a fan (pusing air out) on the front of the projector somewhere where the ballase is as if i have 2x 92mm pushhing air in and 1x 120mm pushing air in and then 60mm pushing air over the bulb there isnt alot of air going out
:smash:
Personally i would do away with the 2 fans you have there and replace it with 1x120mm with a vent directly opposite it on the otherside of the PJ. On the same side the 120mm fan is, mount a 92mm fan on your light engine blowing across the lamp and again out through a vent and/or use your other 92mm fan in a "push pull setup" across the lamp as I have done with my 2x120mm. You will lose a bit of light out of both fans this way but you have a **** load to start with using the 400watt lol...
Well just tried to see if the ballast would fit behind the mirror and i would have to move the support around 3-4cm which would mean the lcd cant go into place, i could mount it on the side but its to tall 🙁 suppose i could cut part of the metal from the bottom off as its only around 3mm to tall but i dont really want to do that and there would be no room for the lcd bord really
