this one reply from Shirley seems to so.Hi Salas,
Any 6v6 preamps out there with an output tranformer that you know of?
Shirley noted 4.5W parafeed in his video. Line preamp 6V6 with OPT they ask about. Such with OPT and especially with NFB must be specifically tested to recommend a type. See first about squarewaves, gain, Zo, bandwidth, preferred load etc. 6V6 power amps featuring OPT there are many examples. Especially small guitar amps.this one reply from Shirley seems to so.
Star ground I see, coax signal wire, local signal grounds, fine. Surely better than before. Better wiring led to no hum result as we projected. Congrats.
What are those black plastic things with a red center on the heater boards? Fuse holders? What is your final power Tx arrangement and what is the raw DC and B+ it finally allowed?
What? OPT load value? Possibly. But I never recommend something as a good outcome without having applied it, measured it, listened to it, first. Especially when there's significant cost involved to get it. Like a good output Tx nowadays. Its DIY and you can experiment of course but its not based on my experiment. No possible info from me on what to get how it will go or how to tweak etc.Could be 5K?
Excellent, because you have difficult taste and you were a bit suspicious about this little shunt NFB version.Salas sounds superb.
Are fuse holders, the red color is the paper where is marked the fuse power: in my case 0.5A.
The custom power tx 275V 0,3A spends minimum 1 week to make it.
PSU 310-313V so Vin for SSHV2
B+ 290V
Thanks for you design, guide, advice & help as usual Salas.
Best personal regards
Felipe
Each one have his own preferences, the 6V6 gets along with noDac & 26. You make happy Salas, cheers!Excellent, because you have difficult taste and you were a bit suspicious about this little shunt NFB version.
I don't like toroidal for B+, other mania: I don't like to share the same powwr tx for B+ & heaters, I like R-Core for heaters but never tested for B+.Thanks for the info. You are welcome.
*New higher voltage Tx will be locally made? Toroidal or EI?
Here is difficult to get people making custom transformers & only for mains power, and the only few that I know always EI, the last maker of custom transformers is retired and recommended a new one, let's see how he does, I asked electrostatic screen to connect at chassis ground.
The prices as all things are skyrockets.
Thanks for the reminder.Don't forget single stage common cathode is inverting. But you can reverse at the speaker connections. Unless your no26 line stage also inverts so the net result is absolute phase correct to be typical.
A pity as he seemed final with his higher mA CCS Mosfet combinations experiments. Field coil spkr on SSHV2Jordi still have problems with the CCS @ SSHV2 for his app
He shall tell me new details in that thread.
Ask for belly band (Gauss band, flux band) magnetic shielding also.I asked electrostatic screen to connect at chassis ground.
- Tubes / Valves
- 6V6 line preamp
