Who said a 35 amp fuse? A 600 rms class AB amp would most likely have around 60 amps in fuses, and unless you ran a full power sine wave the alternator should be able to keep up pretty well. Even if it couldn't, the voltage would sag to 12.5V where the battery would take over the slack and keep it from dropping any more, then as soon as the transient was over the alternator would refill the battery. 600rms really isn't that much in a car, at all. Hell I have more than that just on my front stage....
Anyone who isn't familiar with car audio and is just taking rules and ideas from home audio needs to rethink some things. Car speakers and subwoofers in general aren't nearly as efficient as home speakers, it takes a lot more power just to get to the same level. Then add in road noise, wind noise, and crappy acoustics, and it takes even more power to get up to a reasonable listening level. Not to mention if the individual likes to drive on the freeway with their windows down and still be able to hear the voices in their music. I used to have a 125x2 amp on my front stage and an 800rms amp on my sub and I would have to drive both of them nearly into clipping just to have audible output on the freeway with my windows down. It takes an enormous amount of power to overcome the imperfections in car audio, unless you always drive with your windows up, deaden your car so much that it sounds like a mercedes, use multiple pairs of components in the front, and a ported 12 or a sealed 15 for the substage.
