may be useful .. pcb B500 scp (signal, clip, power indicator) already tested ok ... thank Apex Audio ..
Nice work
Sorry Arif, but traces are grey so no
home etching is possible .
Did you have this traces in black ?
Thimios.
Thimios.
black bottom
sorry sir... like this...???
arif smd
Thimios.
arif smd
Thats it!sorry sir... like this...???
arif smd
Thanks .
sir how can we get nsl32 since theres no availability in our area,, wat is the function of this in the circuit,, if no availability is there any replacement for this nsl32..???
if you not use nsl32 is no problem. the fuction just limitter, this amp can work fine without nsl32.sir how can we get nsl32 since theres no availability in our area,, wat is the function of this in the circuit,, if no availability is there any replacement for this nsl32..???
you can use ldr + led instead nsl32, please read post before..
regards.
maybe this usefull for u. Audio Amp Power Limiter
If they'll ship internationally, NSL32 are available at:
NSL 32. - ADVANCED PHOTONIX - OPTOCOUPLER, 2KV, RESISTIVE O | Farnell UK
Results for Opto Devices, Thermistors
Silonex - NSL-32 - Optoelectronics & Lighting - Optocouplers/Optoisolators - Allied Electronics
I think Mr. apex made amplifier girlfriend or wife is a pink out
or for birthday..
sir i have a transformer 65-0-65 ac is this ok for this b500 amplifier circuit..??
please go this page : http://www.diyaudio.com/forums/solid-state/164208-500w-pa-amplifier-limiter-4.html#post2147823
Hi Apex.
Can you direct me to your page which features the H900. Will it work on 100 - 100Vdc Supplies(68-0-68Vac)?
Regards.John
Regards.John
sir wat is the replacement for mje340 and mje350 since no available her in our place...
try go to this page http://www.diyaudio.com/forums/solid-state/164208-500w-pa-amplifier-limiter-3.html
Hi Apex.
Regards.John
what u mean, 100vdc for mv or hv?
this original posted from apex.
Power suply 0,+/-60V,+/-120V. THD 0,03% 20-20000Hz on 900W 4 ohms. All new brand amplifier use 4 pairs of 1943/5200 evan for 1900W 2 ohms in their specification. I dont want to go tnat much.
Hi there.
My AC supply is 68 - 0 - 68 volts AC.
After rectification and smoothing it comes out to +97 - 0 - -97VDC hence my request for a design that can handle + 0 - 100Vdc (to allow for mains fluctuations ).
Regards.
John
Regards.
John
Hi there.
Regards.
John
maybe u can goest to 100vdc but add more output or use mjl .
try to search from here http://www.diyaudio.com/forums/solid-state/162408-900w-h-class-pa-amp-limiter-192.html
- 500W PA amplifier with Limiter
