no nsl32hi engel dela pena
greetings congrats for completing amplifier
did you use nsl 32
thanking you
andrew lebon
ldr+led only
engel dela pena,
nasty dust over those fans.
no problemo amigo,
wait for her revival he he he
that was my old amp quasi n fet psu specs is very good for b500
i replaced with b500 module
Is this opto ldr? What is pin layout?In Russia you can get an approximate analog aor124
rock soul & jazzengel,
what kind of music you listen?
good sonics
engel,
sir what components are hard to find in our country???...your from what city???...
b500 is friendly here unlike the h900,
no IR2117
nsl32 also,
i'm from malolos,
but i got most af the parts also from manila
Bulb have positive temperature coefficient (PTC). When bulb is cold it have small resistance, when current rising bulb get hot and resistance is R=U2/P. U=220v, P=100w and R=484R when bulb bright, that resistance will drop voltage on primary and protect amplifier if something is wrong.
Resistance of 150R will drop voltage on primary if current rising. Voltage on primary will be U=220v-150RxI(A), voltage drop will protect amplifier is something was wrong also like bulb.
bulb is very bright during first power
after the in rush current
bulb start to dimmed
When during first power, caps are charging and current is high.bulb is very bright during first power
Thanks, I like case, it is more robust than NSL32.Here are the details in Atach
Look like AOR124 is perfect for B500, if pins layout is right, but that will be smal problem.Here's a similar example!
Like me,rock soul & jazz
good sonics
Cheers
- 500W PA amplifier with Limiter
