4xtda1541a Nos Dac Project
Joined 2009
JC951t said:
Hi Dvb,
Hows the sound of the Lampizator with 6n2p ?
Have you tried with 1 tda & 2 tda . If so how much
difference is it sound wise ?
TQ
With the delivered parts on the DAC and the Lampizator SRPP circuit with 6N2P (Dale RN55 I/V resistor), it plays equal to my PS Audio DL III with Cullen Circuit Stage IV Mod.
And this is a realy goood one.
Now, with the Black Gate 100µF N-Type on the 3 powerlines, 0,47µF NX HQ-Type for decoupling and 0,1µF NX HQ-Type bypassing each of the 7 regulator outputs, it plays in another league! :angel:
Next tweeks are:
- PS with Tube recifier (6X4) for the HV of the 6N2P
- I/V resistor change to TX2575 Naked Bulk Metal “Z” Foil
I think, that´s it. :rolleyes:
I only run the DAC with all 4 TDA´s. So i couldn´t say anything about the difference to 1 or 2 TDA´s.
Best
dvb-projekt
I tried the 6n2p option with one tda1541 and I can tell that I prefer by far the alternative with D3a or e280F triode connected,150V 10mA choke loaded,
5852 Bendix rectification,it yields a much more open sound very sharp and smooth, passive I/V resistors 33 ohms...
I much encourage people to have a try.
Well I did not remove the 470pF caps, they are still in the circuits.... I just tied pin 16 back of 3 slaves to pin 16 the nominated master pin 16 with 100pF cap. It seemed to improved the sound, imaginary or not.... :)
One of my next mods is a total DEM reclock, like you talk through.
jk
-ecdesigns- said:
Unfortunately you can't slave TDA1541A DEM oscillators this way. When you remove the 470pF caps from the other 3 TDA1541A chips, the DEM oscillators of these chips will oscillate at maximum frequency (around 7 MHz) due to stray capacitance. This frequency will simply inter-modulate with the approx. 250 KHz DEM oscillator from the master.
The following problems have to be solved:
This way all TDA1541A chip DEM oscillators can be clocked synchronously.
Joined 2009
:cloud9: work for the next weekend....
The new I/V resistors TX2575 from Texas Components arrived today!
I will also do the Tube rectifier upgrade for B+ of the 6N2P, with:
- 6X4 Tung Sol rectifier
- CRC Filter with Mundorf TubeCap´s
- new Tentlabs E-Choke
So, let´s see..... :cheers:
DEM RECLOCK
Hi John,
in Post 35 and the attached Schematic you are powering the inverter IC with 10v derived from the -5 and -15v lines.
I am using a differential line driver (DS8921) to create the balanced DEM clock signals, which is powered by +5v. Is it worth me powering the DS8921 chip with the -5 and -15 power in the same way to create the negative offset in the DEM reclock signals?
Brad
No it runs on approx. 5V DC (-5V minus voltage drop across 5.1V Zener diode D1). So the 74HC00 GND connects to -15V and the plus connects to approx. -10V.
The DS8921 can also be used, but it might require a separate voltage regulator:
UA7805, input to -5V, GND to -15V (creates positive 10V input voltage with respect to GND pin), output then provides +5V with respect to -15V supply.
But it's better to use the discrete LED referenced power supplies (much better sonic performance compared to 78/79xx regulators). I attached schematics of these LED referenced voltage regulators (+5V, -5V, and -15V).
For the DEM clock mod you would need two of these +5V regulators.
Joined 2009
So my friends... The first work is done. :)
Changing the Lampizator rectifier circuit to a real good tube rectifier circuit with the new Tentlabs Electronic-Choke.
My circuit based on the Tungsol 6X4WA, with separate transformer for the heater,
with the new Tentlabs e-choke module
As recommended i change the input capacitor from 330µF to a 10µF TubeCap (MKP) from Mundorf.
The module replaced a normal iron choke and offers up to 60dB supply ripple reduction.
The output capacitor after the e-choke must be a 330µF (in my case the original one).
The last two caps are also Mundorf TubeCaps 10µF.
Here the actual complete DAC:
Tomorrow i would like to change the last parts:
- Input circuit caps to OSCON Caps
That´s it... :D Ohh, i forgot the case. I have this ready in my mind but it will take a while.
@ Markuzz:
Please ask the board admin for help, because i couldn´t mail (only to full members).
