4P1L DHT Line Stage
Wow, this tube is starting to become famous. Soon we'll see a shortage worldwide...😉
The reality is that it sounds is amazing. I am building now the third amp using it.
Just that one needs a high sensitivity speaker..
Radu
Spent emission
I hope not! 🙁
In pic three and four I cleaned the glass with some toothpaste.
Indeed. I'm going after my third incarnation of the "Siberian" preamp. I will run the 4P1L rather hot at 35mA with an LL1660 in 4.5:1 to provide low output impedance and drive to my system.
Just started filament supply - choke input 🙂
Siberian DHT Preamp Gen3: filament supply | Bartola Valves
cheers
Ale
Hi Ale,
In my last built PSE I tried it at 40 mA and was the best sound right there.
My OPs were 70 mA so I had to let them run at 35mA, 250V.
I am curious to find out how long they will last running them at 10W.
I have to figure out how to run a accelated test at 40 mA. I dont want to spend 6 months to figure this out.
Best,
Radu
Talk of questionable 4P1Ls reminded me that I bought some a while back but I've never used them. I've just had a quick look at them and wonder if some might be a bit dodgy. They were sold as NOS but at least half of them look a little "milky", perhaps like Bas', though it looks to be internal. In the attached photos the valve which looks good is on the left and the dodgy one on the right. Might they be less than perfect?
I'm convinced mine are new. They look almost identical too the ones posted on Siberian shop's versions. Why would they post ones with visibly spent emmision. The base and pins also don't look tarnished whatsoever...as is the case in one of Kevin's 4p1l's.
attachment.php
Did not see anything there
Sockets FOR Tube 4P1L 4P1? RL2 4P6 Wermacht X 2pcs | eBay
This could offer opportunities to add sound-dampening material to the cylinder of the socket.
Are these bottom mount phenolic mounts?
I found some made by EDISWAN that seem like they could be good.
Reminds of when Harry Pearson's favorite 12AX7 was made by EDISWAN.
I like the idea of phenolic better than ceramic.
Ordered some 4P1Ls today along with the COLEMAN filament regulators.
