300B advice
I have never heard the Kaiju, or any Bottlehead amp for that matter.
Over the years I've heard Cary, Wavelength and Grant Fidelity SE 300B amps, along with a number of homebrew amps, and I've personally built SE 300B and 845 amps with Magnequest, One Electron and James output transformers, using a number of different driver topologies. I've also heard and built a number of PP amplifiers. Of course PP is different from SE, but both have their plusses and minuses, and both are capable of making beautiful music under the right circumstances.
Reactions: lickumms
They are small because it's a parafeed design. The output tube load is a plate choke, which is cap-coupled to a small but high-quality output transformer. This relieves the output transformer of having to handle DC current and allows for a smaller but better-bandwidth design. It's intentional.
Thanks, Grover. I thought I might amplify this a bit, hope that's OK with the moderators.
On top of the Kaiju chassis plate, there are only the plate chokes and power transformer. Under the chassis, and mounted with the same screws, are the output transformers, which are the same size. They weigh about 2.25 pounds (1kg) each. I designed the windings to approximate the Magnequest parts (EXO-003 and TFA-2004) we had used in an earlier 300B amp (ParaBee), and the MQ set pretty much weighed the same. Bass performance is pretty similar to the series-feed FS-030 which weighs about 2.5 times as much (11 pounds/5kg). Specifically, inductance is 40 henries and the OPT full-power bass bandwidth is about 22Hz. Parafeed really is more weight-efficient.
As it should be with 86db speakers sporting "sluggish " poly cone. I read opinions about success people had with Proac Response 1 and 2 with Set amps but having both of those speakers and some Set amps it wasn't my experience. The only Set " Magic " I ever experienced was 40W of Belcanto SE 40 -845 amp on 100dB system with horn top end and active subwoofers below 80 Hz . It had speed rivaling Naim and explosive dynamics with only a hint of so called elephant sound.. Well maybe , Lowther on a good day with front Azura horns had something going on with 45 amps I built, junk that they were ( Yamamoto clone ) Admittedly real Yamamoto was quite a bit better
as it has very good custom
C,-core trans and my 45 had basic O-netics trans.
The secret to good audio is to do opposite to what people on Audio and DIY audio forums are advising🙂
I've read that 845 amps produce a rather "aggressive sound." Is that similar to what you heard with your 845 amps?
In my experience, any graphite-plate tube can have a more "aggressive" sound if not handled properly--this includes 845, 6336, 6528, etc. My 845 amps (I built two sets of monoblocks which are still in use by friends) did not sound "aggressive" but I took care with the filament supply and other components to ameliorate this. Years ago someone made a graphite-plate 300B, and I see Shuguang still makes them. They certainly sound different from the standard metal-plate variety. There were also metal-plate 845s available at one point, but IMO this defeats the purpose. ;-) One advantage of graphite plates is that they can produce a more robust sound.
The board was professionally built and then reinspected by my tech friend for consistency. It has the Lundahl OPT upgrade. Caps are stock. I have EH Gold 300Bs in it, along with some very good NOS preamp tubes. We were both very much looking forward to hearing it but were disappointed by the lack of dynamics and vocal and instrumental texture. I have original ProAc Response 2's, and while they aren't terrible efficient they are quite SE-friendly. I used them with my own SE 300B amps for several years with real pleasure, and my friend has his own 300B amps. So neither of us is unfamiliar with the plusses and minuses of SE amps. All I can tell you is what we heard. Possibly the auto-bias prohibits clipping, which under these circumstances would limit the behavior of the ProAcs. We just did not enjoy the sound, and after 30 minutes swapped the Elekit out for a 12 wpc stereo Pilot EL84 amp I had just finished restoring. The difference was night and day.
The least wimpy 300B amp that I've heard is one that uses an 2a3 as driver via IT to 300B. dynamics & bass in spade. It was driving a 86db Dali book shelf speaker
I believe stock caps are Nichicon metallized poly caps and "Upgrade" caps Mundorf silver/gold/oil, which can be improved upon as well. I used Jupiter copper foil caps to replace Mundorfs. EH 300B are decent 300B, but unfortunately, more decent 300B's cost WAY more.
But I use the amp on speakers with sensitivity ranging from 90+ dB to 100+ dB horns, usually without passive crossover in the way, so the circumstances cannot be compared..
No, I don't. You would have to use a choke load or IT because it needs a lot of B+, same as the 300B really. It may be that I tried it with the 845 because I had loads of B+ to spare and just did a 10K plate load or something like that. And it was an 801A I used.
The high end audio market depends on this mindset!
https://www.takefiveaudio.com/contents/66-burnin
Are you familiar with High End market ? Meaning, you had high end pieces at your home in your system ? Or just listened to accidental setups on Audio Shows? Don't get me wrong. I don't like mainstream High End sound but most here do and want to copy it for cheap. Problem is they almost never have the pieces they copy at home and are convinced they are getting the same exact results.
My remark was general in nature and the rule applies universally. Spend the money upfront so you won't have to spend it twice.
