3-way studio monitor design
I'm also looking for documentation about cardioid speakers. Not a lot on it. To me it seem passive cardioid is one of the most effective way of reducing front-wall reflections.
The D&D are relatively big for my room. I wonder if it would be possible with a smaller 6-7 inch woofer at the front and 1 or 2 6-7 inch woofers on the back.
Going completely active is also possible. It is done by Kii on their Three model.
Thanks hammersandwich, very interesting!
From my readings modeling such a design it's quite difficult. A lot of trial and error in all the threads... and you need to be able to do measurements in a correct environment.
I'll stick to sealed design for the moment. I've ordered Satori MR16P-4, Dayton RSS210 and waveguides... already have two R2604.
Maybe later I'll experiment with active cardiod with another RSS210 a separate box on the back. I'll keep you updated... my build will start at the end of march.
Hello everybody!
Has been quite a long time since I started this thread.
In the meanwhile I solved my necessity of monitoring in surround getting my hand on five pmc tb2+ that really do the job.
But this project was still somewhere in my mind and now, thanks to the loss of work related with the pandemic, I have the time to go on. I bought the missing parts to build a pair of those and started the wood working this week.
The chosen drivers are:
woofer: SB Satori WO24P-4
mid: SB Satori MR16P-4
tweeter: vifa XT25C30-4 with WG-300 waveguides.
The idea is still a WTM sealed box, 30 liters for the woofer and 11 for the mid.
I would like to experiment on the mids, controlling the directionality with a sort of damped U frame, I'll keep you updated on this... pictures are coming..
One of the speakers is finished, I did some crossover design but outside is raining hard so can't do real measurement...
Some more pictures of the stuffing:
Thinking about the next move: adding two subwoofers...
One possibility would be to use them as stands for my speakers, so around 80l... or separate cubic boxes.
Now the eternal question, what driver should I chose?
I would like to go sealed, but considering also PR, go deep, very low distortion, fast, dsp with minidsp or fusionamp.
Budget around 250€ driver.
There are many drivers out there that can do this, my selection for the moment:
dayton UM12-22
dayton RSS390HF-4
Peerless XXLS 830845 or 830844... with PR?
Peerless 835017 or 835016
SS 30W/4558T00 + PR (more expensive around 380€ for SW+PR)
SDX10 CSS, but can't play that loud in the mid 20Hz
do you have some advice based on real world experience?
Thank you very much!
Here is a link to my project
New active 3-Way, Hypex and SB
I used the SB34NRX75-6 in a 70 liter sealed box. The ideal box size would have been 110 liters, but since I was using DSP active crossovers anyway, I applied a 2nd order shelf filter to extend the bass response (Linkwitz transform). Boost starts at about 38 Hz, and I have 6 dB of boost at 27 Hz. This results in a system which is flat to 30 Hz, and then rolls off at 12 dB/octave below that
