3 way crossover design advices
The sealed box can not be change , I allready order it should come to me soon .
thanks
Ok looks like you made the circuit well done , but it is not normal to build such big circuite 😱 perhaps we could make more simple circuit . or maybe replace the midrange to more suitable driver
here is project it should look like that ?
three-way crossovers are almost always big and complex if done properly.
you might be able to simplify by using a midrange with more flat response, but i doubt that.
considering that mounting the tweeter from behind the baffle is no good idea (unless you have a precise idea of the waveguide you want to build) and you want to simplify the project and use the existing enclosure and the woofer you might be able to change the project to a two way system with a 5" fullrange and a low crossover frequency.
maybe something like this: 10F/8424 & RS225-8 FAST / WAW Ref Monitor
