hello all
I want to build sealed speaker with this items
1. Dayton Audio DS315-8 12" Designer
2. Goldwood GM-65/8 Sealed Back 5-1/4" Midrange 8 Ohm
3. HiVi Q1R 1-1/8" Textile Dome Tweeter
I have already have them .
The box is gone be 37X30X70 cm and will get it soon .
The question is about the crossover .
The woofer has a peek on 1KHZ-2KHZ and have to terminate it and crossed about 600-700HZ .
what else we have to take care of ?
Then the next thing to do is applying baffle step and diffraction response to traced files. While doing that, you can add enclosure loading response (reflex loaded). There is multiple software solutions to choose from. Use search function of this forum. If you would like additional help in simulating crossover, make a drawing of the baffle, clearly showing driver positions and their respective coordinates (x,y) beginning with a point of origin (lower left corner). Example, baffle is 37 cm wide, and 70 cm high. Tweeter positioned in the middle and 60 cm from the floor= Tw(18.5; 60)...etc.
- 3 way crossover design advices
