• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
2x150W Amp module for sale
Thanks to Yatsushiro‘s help to reply the PE ground question.
With increasing the value of the resistor at the I/O buffer board, it can slightly keep the unit gain for the I/O buffer.
And, for the toggle switch, you can take it as the soft switch, it will shut down the Main SMPS, and the aux SMPS only can output 12V to save power.
Thanks, Eric
Reactions: Yatsushiro
Thanks for the suggestion. I'll update the first thread to consolidate this information ~
Something like this is easier to glance at:
FFA001_V3
Output: 2x150W @ 4 / 8ohm
Input: 85--265Vac, constant power SMPS
Price: USD$49.9/Unit, w/o shipping
Notes: Can be configured as a high-bass mode. CH1=300W@4OHM and CH2=120W@8OHM, similar to the Pascal U-PRO2
FFA002_V2
Output: 2x350W ...
Input: ...
Price: ...
FFA002-V1
Output: ...
Input: ...
Price: ...
Notes: variant with MOSFET mounted at the bottom side of the PCB
FFA003
Output: 1x350W ...
Input: ...
Price: ...
You can always add more to the list in this format and potential buyers can easily keep track of your offerings.
Reactions: Erica.C
Hello Friends~
Please refer below Pic to modify these two resistors to 49.9K or above to keep the unity gain for the I/O board. Currently, there is a 6dB gain in this board.
Thanks,Eric
I have 3 FFA001 doing endpoint duty for Roon around the house. This is the FFA003 and will go into my main listening system in the living room and I want it to be as good as it can be. I am having the face plate at a machine shop being milled for meters and power switch. Putting these into the chassis was like trying to put 12 tomato’s into a can.
