• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
2x150W Amp module for sale
Hi, Bill
During mid of this month, the I/O buffer with DIP opamp/Volume control will be ready, then we can open the first -batch order for friends. Sounds a little delay than the schedule. while more resources are put into working on the universal FFA002V2
Thanks,Eric
Reactions: Hipocrates
Hi, Nick
Currently, we only design this for the FFA003 IO board, we have not re-designed the FFA001V3 IO buffer. So, no worry about your choice today.
If I do re-design the new IO buffer for FFA001V3, I'll announce it here 😉
Thanks,Eric
Hi. I bought and received an amp with unbalanced buffer board and am just now getting round to building a case. My question is how do I connect a volume pot to it, and what impedance pot should I use?
For the current I/O buffer circuit design, I don't think there is a proper way to wire in the pot. It's better to have a pre-amplifier for your system.
Thanks,Eric
Reactions: CANNON-FODDER
@Randy Bassinga you might go back and review the six channel by @von Ah (here and in other threads). IANA[EE] but if three boards coexist, changing the power limiter on one channel doesn't seem like it would make them fight. If you need more power than (whatever the base power line is there, it's ~15A here) you are now into breaker limits and separate lines run from the main power box anyway.
Reactions: Randy Bassinga
Hi, All
Announce this FFA003V1, universal power supply(85-264Vac), mono output amplifier;
8ohm -- 150W;
4ohm -- 300W;
With XLR balanced input, and volume control. 🙂
