Some swear on them, even in this board. I for myself do not have any experience with SS relays in amplifier outputs.
Best regards!
Best regards!
Dear Kay,
thx! Maybe never a SS relay because of added nonlinear distortions. Here I use Panasonic JJM1a or JJM1 with high current contacts with very low resistance.
BR, Toni
He he, you know the other road to the Rome, may be you walk on this road in the future.😉... low ohmic Rds-on MOSFETs (< 10mOhm) are expensive. You need 2 of them and some extra parts like special optocoupler with a photovoltaic cell inside to provide the gate voltage. Maybe you need some sort of extra protection for electrostatic safety too...
I like the silent "click"-sound when the speaker relays are contacting ... 😉
Have you ever measured an SS relay?...
I have Bonsai's NX with it's SS relays on the PSU and that minimal capacitance when OFF is not an issue.
Both 😉SSR in the rail voltages? Or on speaker outputs?
No !Both 😉
Dear Harry,
No!
Maybe worth someday to do some testing especially in the sensitive 1W power range. If one can recommend a diy audiophile speaker SSR ...
BR, Toni
Thx for offer! I only need some MOSFETs and the photovoltaic optocoupler for testing. Maybe I will buy some parts for testing in summer if I find the spare time.
On a future todo list: designing a mini pcb to be able to replace the JJM1 relays.
Have fun,
Toni
Did you measure distortion between mosfet's input and out to compare?I did run into an anomaly with one SS relay design in a very compact layout that was showing some distortion. I'm not sure of the cause but it was located very close to a control transformer and may have been picking up some EMF in the gates of the mosfets? I'm waiting to get better test equipment to investigate farther.
Why you don't use your p.c sound card?I measured distortion at the output of the mosfets and at the amp output with the mosfets disconnected from the circuit. The distortion analyzer I was using is and hours drive from me so I don't use it often.
