Try to add resistances and inductances of wires into your SIM, variable current drawn, and you will see why ground sign have to be drawn near C3 instead of near C1.
I always read all people said to connect the ground to 1st cap psu
Felipe, that's not my design. Either way 12mvpp ripple is not bad at all! Are you planning to use a shunt regulator?
Ale
I'm sorry Ale the post was for Andy. Yes, Salas hig voltage shunt regulator version 2
Felipe
Felipe, can I do some comments?
Such a low transformer DCR not optimal for (mesh) AZ1. It would be better 100-200R DCR.
IMHO C1 low, thus output voltage also low. There are no high charging current (AZ1 unable to do so) therefore increase C1 up to 1-5uF. If output ripple bothering you, increase C3.
ps. PSUD a little cheating, output voltage about 220V, not 230.
Ps2. Attachment is my working #26 preamp (common raw PSU- each side: SSHV2- cascode CCS loaded 26 -TVC) raw HT supply.
Of course you are welcome, you are right because one time for other project I use AZ1 with other transformer with secondary DCR 83,2 ohms and was to add one resistor in series with the phase of 78 ohms or AZ1 not optimal.
Thanks for support and advices
Ale I have simulated your PSU, simulator saids have more ripple, or I'm misunderstanding something, see attached image.
In simulation you have 10H 10Ohm chokes for 30mA
More realistic would be 100 to 300Ohm choke. That can make some difference on the outcome
Thanks for advice, could I add in series resistor 290R? could you elaborate so I can learn? psud2 don't show any difference of ripple.
Thanks for advice, could you elaborate so I can learn.
10H chokes have thousands of spirasl in a iron (typically) core, so you cannot use big seccion wire, or it won't fit, or it will be enourmous and very expensive.
So you use thin wire (as requested by the 30mA), so wire resistance will be a lot higher than 10Ohm. Fro experience (I build them myself) for a 10H 200mA choke resistance will be about 100Ohm and for a 10H 100mA typically about 300Ohm. For 30mA could be more.
If you make that change on the simulator you will see that output voltage and ripple are a little different.
By the way, 0,1Ohm on caps is also too low if you're using electrolitic.
Cheers
Cheers
Thanks for advices, I use Bartolucci chokes are rated 10H 100mA 10 ohms, attached pic.
I'm using mkp in oil ASC X386S, attached pic.
Cheers
Felipe
P.S. How can measure lytics impedance?
Why not?
did you measure inductance with 100mA?
No Felipe, Wavebourn is absolutely correct. If you use R or L, the new ground point becomes the lastest Cap minus pinI always read all people said to connect the ground to 1st cap psu
Now you know better than "All people that said"
I like to learn
FINISHED!
Last photos of my implementation: The Supply Chassis!
Final result: Incredible clear #D presentation, dead quite with virtual zero noise on the speakers (even with your ear deep inside the mid/woofers).
I am very happy, the final result is really impressive.
Thanks to all (Thomas, Ale, Kevin and Rod) for your strong help and support.
- Tubes / Valves
- #26 pre amp
