#26 pre amp
Thinking of testing different tubes with this same circuit instead of 26 tube. Any suggestion for matching and fine sounding alternate tube for 26?
You are going to have to change the filament voltage for just about any other tube. If you can vary this voltage, then I would try the following tubes in the same circuit: 10, 56, 112. The 56 and the 10 can handle higher plate voltage, and make sure to check the plate load. The 56 is indirect heated and also different socket, but it shouldn't take too much modification to get there. I wonder if for the 56, you could tie the heater to the cathode and run it like a DHT? I hope you have a variable filament supply!! 😱
Thanks Eboz. Changing filament voltage is not a problem for me. But which of the tube has the most superior sonic advantage out of all these?
I think you should try all of them, really. But if you have to choose one, I guess the 112 as it is similar and possibly exceeding that of the 26. Try it and let us know! 😀😀
Alternatives to 26 are 10Y and 01A for good sound. I've tried a bunch and that's what I'd recommend for a line stage. I actually like 1G4G but it's too microphonic for general use. VT-67 is a good sound but 10Y and 01A are better. Haven't tried 46 in a line stage - may be interesting.
Andy
i use one cricuit for tube 26, 45, 6c4c. it is very exelent, no hum no noise.
you see:
http://www.diyaudio.com/forums/tube...-all-tube-dht-amli-26-45-2a3.html#post2189580
Thanks guys for all your suggesstions. I will try whaever possible and post the results eventually.
Latest thoughts -
One thing I did over the weekend is change my 26 preamp from choke load to Hammond 126C output transformers. Very clear and detailed sound. Quite a forward sound. I don't have the best speakers connected right now, so hard to be more precise.
I got the 180v for the anodes from VR105 and VR75 glow tubes. I'm running at 6.3mA with 12.5v on the 1.9K cathode resistor (bypassed with 47uF). That's right on max, but it does give me the lowest anode resistance. May review this and bump up the cathode resistor value up to nearer 2.4K.
Just turned it on, so probably needs to settle in a bit. Any comments welcome!
Andy
Hi Andy,
What is the bass like? The inductance has dropped to about 106 Henry, maybe more since you are only running 6.3mA out of the max 15mA.
How does it compare to the Lundahl?
I have some Silk interstage XF's but they're on 5K, the 10K L941S may be an another option. Also you may have more gain when compared to 15K - 20K line output transformers.
Rich
I only have some 6 inch wimpy full range speakers - not even that because they're not really full range - so I can't do much critical listening. But it seems to me that the bass is there. I think it's a good sound and well worth trying, since the 126C is fairly cheap and available. A friend who uses it measured it and said that the treble response is very good, though 15ma is the limit you should go to. He was using 10mA.
With this output transformer in place, it begs the question of whether I should change to a 10Y. I'm even wondering about a 46. Anyone used a 46 as a preamp? It's a great driver.
Andy
just do it man!
Then you can tell us how much better the Hammond is compared to the Lundahl in your 10Y linestage and we can do a Hammond 126C group buy ;-)
I have a few sitting around and was thinking about using one in a dac output for a while, could use my 5K interstage as an output XF. I recall someone using a 2A3 in a similar role somewhere and our brother in arms, Mr Lampizator has recently used a 300B.
DAC300B
Rich out
Ok guys. Let's hear it for the 46!
I knocked up a board to plug in 5 pin tubes to my 26 preamp, with the 126C Hammond outputs.
Sound is extremely neutral. Well everyone says that about the 46. Bass is solid and good. It's very quiet. Plenty of detail. So far so good, and indeed it is good.
Compared with the 26 I just miss that frisson - the added vividness, life and zing. It's not that the 46 is flat - it's just neutral and bo doubt that should be good. I just miss the 26.
I tried the ST version of the 46 - NOS Tungsols. Nothing wrong there. Didn't try the Globe. May try that later when the ST sound has sunk in more.
Andy.
So suddenly on page 46 of this thread, it's transformed into a thread on type 46 preamp! Heh... I mostly hear of the 46 replacing the 45 with a few minor adjustments. I have all of the above tubes in-hand, but too many other projects stacked up at the moment to get to these tubes. I rather like to skip the preamp (at least as a stand-along component) and simply use DAC's output and the main amp's input stage as pre-amplification.
One thought I have is grounding the grid of the 26 and finding as low gain JFET as I can to place under the cathode. It's still too much gain, but could try dividing the input voltage. The 26 by itself is too low to fully drive a medium size tube such as 2a3 or 45 into clipping.
I think the "preamp" is a bit of a virtual concept. What we simply have is stages of amplification, wherever they are physically situated. The total of what's in those stages, however many there are, is the amplification chain. A lot of tubes can be moved around in this chain, two of the most obvious being the 46 and 10Y - fine anywhere from input to output.
I tried the globe 46. More delicate treble, bass not so solid. Swings and roundabouts. the globe is really nice looking though!
If I have the energy I'll go on and try the 49 and maybe the 24a. I previously did a whole shootout of 4 pin DHTs and the ones I liked best were 26, 10y and 01A. The last two thoriated which may make a difference.
andy
OK, now for the 49, now we're tube rolling.
Now this one is very good. Nice tone, delicate and detailed treble. Nice life to the sound and very clean. I like this a lot. It's struggling into a 126C since that's rated at 10K (106 henries) and the plate resistance of the 49 is around 11K. Not a match but still sounding nice, though bass is light.
I'm going to leave this one in for a while. I must admit the 46 came out after a couple of CDs - got a bit bored with the sound. This 49 has me a bit intrigued. Would probably sound good into a LL1660. It sounds quite like a 01A, and is of course much cheaper.
Andy
